メインコンテンツにスキップ
Marshall Kilburn Power Switch Replacement
必要な工具と部品
  1. Marshall Kilburn Power Switch Replacement, Battery: 手順 1、 2の画像 1 Marshall Kilburn Power Switch Replacement, Battery: 手順 1、 2の画像 2
    • Place the unit face down as shown in the picture, exposing the battery cover.
    • Remove the two 4.0mm long screws holding the cover on using a T10 driver.
  2. Marshall Kilburn Power Switch Replacement: 手順 2、 1の画像 1
    • Remove the battery cover using a fingernail or nylon spudger.
  3. Marshall Kilburn Power Switch Replacement: 手順 3、 1の画像 1
    • Remove the battery and unplug the power lead.
  4. Marshall Kilburn Power Switch Replacement, Power Switch: 手順 4、 3の画像 1 Marshall Kilburn Power Switch Replacement, Power Switch: 手順 4、 3の画像 2 Marshall Kilburn Power Switch Replacement, Power Switch: 手順 4、 3の画像 3
    • Place speaker as shown in image and remove the four corner 45.5mm back cover screws with a Phillips #2 driver.
    • Using a Phillips #2 driver, remove the six remaining 21.5mm outer back cover screws.
  5. Marshall Kilburn Power Switch Replacement: 手順 5、 2の画像 1 Marshall Kilburn Power Switch Replacement: 手順 5、 2の画像 2
    • Remove the back cover by using the vent hole as a grip.
    • Gently pull out the back cover and let it hang on the side of the speaker that has the knobs and power switch.
    • Unplug the main power lead from the control board; this allows the back to be opened more, allowing easy access to the power switch.
  6. Marshall Kilburn Power Switch Replacement: 手順 6、 3の画像 1 Marshall Kilburn Power Switch Replacement: 手順 6、 3の画像 2 Marshall Kilburn Power Switch Replacement: 手順 6、 3の画像 3
    • Pull the back cover attached to the motherboard to the side as shown in first image.
    • Remove the white insulator from the stereo speaker and place it to the side.
  7. Marshall Kilburn Power Switch Replacement: 手順 7、 2の画像 1 Marshall Kilburn Power Switch Replacement: 手順 7、 2の画像 2
    • Place the speaker up right, and unscrew the golden bolt around the power switch with your hands, or a wrench.
    • Gently pull out the power switch as shown in the image.
  8. Marshall Kilburn Power Switch Replacement: 手順 8、 3の画像 1 Marshall Kilburn Power Switch Replacement: 手順 8、 3の画像 2 Marshall Kilburn Power Switch Replacement: 手順 8、 3の画像 3
    • Use a slim spudger to wedge out the four red wires attached to the power switch.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Jeff Feuss
メンバー登録日: 01/14/19
423 ポイント
3のガイドは作成済み
チーム
2 件のコメント
And where to purchase a new switch???
Anders Skipper - 返信
Does the old switch have any writing on it?
Andrew S -
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 20
過去 30 日: 64
今までの合計 4,804
