はじめに
This guide will show you the necessary steps to locate and replace the LED light. It shows how to remove the battery and the outer casing in order to locate the LED light on the drill.
必要な工具と部品
Hold the drill upright with the back panel facing you.
Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
もう少しです!
終わりに
2 の人々がこのガイドを完成させました。
