はじめに
This guide will show you the necessary steps to locate and replace the forward/reverse switch. It shows how to remove the battery and the outer casing in order to locate the forward/reverse switch of the drill.
必要な工具と部品
Hold the drill upright with the back panel facing you.
Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
Pull the silver metal clip located towards the back of the motor assembly away from the drill.
ある他の人がこのガイドを完成しました。
