メインコンテンツにスキップ
Makita XPH01 Clutch Leaf Spring Replacement
必要な工具と部品
  1. Makita XPH01 Clutch Leaf Spring Replacement, Battery: 手順 1、 1の画像 1
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 Clutch Leaf Spring Replacement: 手順 2、 1の画像 1
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 Clutch Leaf Spring Replacement: 手順 3、 1の画像 1
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 Clutch Leaf Spring Replacement, Outer Casing: 手順 4、 2の画像 1 Makita XPH01 Clutch Leaf Spring Replacement, Outer Casing: 手順 4、 2の画像 2
    • Hold the drill upright with the back panel facing you.
    • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
  5. Makita XPH01 Clutch Leaf Spring Replacement: 手順 5、 1の画像 1
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  6. Makita XPH01 Clutch Leaf Spring Replacement: 手順 6、 2の画像 1 Makita XPH01 Clutch Leaf Spring Replacement: 手順 6、 2の画像 2
    • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
  7. Makita XPH01 Clutch Leaf Spring Replacement: 手順 7、 2の画像 1 Makita XPH01 Clutch Leaf Spring Replacement: 手順 7、 2の画像 2
    • Apply slight pressure to the sides of the outer casing and pull away from the drill.
  8. Makita XPH01 Clutch Leaf Spring Replacement, Clutch Leaf Spring: 手順 8、 1の画像 1
    • Pull the silver metal clip located towards the back of the motor assembly away from the drill.
  9. Makita XPH01 Clutch Leaf Spring Replacement: 手順 9、 2の画像 1 Makita XPH01 Clutch Leaf Spring Replacement: 手順 9、 2の画像 2
    • Grip the motor comfortably towards the front of the assembly, and pull it away from the outer casing.
    • The wires are still connected to the back of the motor assembly, so use caution when pulling the motor out. Failing to do this will result in parts falling off the back of the motor.
  10. Makita XPH01 Clutch Leaf Spring Replacement: 手順 10、 2の画像 1 Makita XPH01 Clutch Leaf Spring Replacement: 手順 10、 2の画像 2
    • Slide the clutch leaf spring off with the spudger.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Eric Herwatt
メンバー登録日: 10/05/16
1,020 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 15-4, Livingston Fall 2016 Cal Poly, Team 15-4, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S15G4
4 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 32
今までの合計 3,121
