メインコンテンツにスキップ
Makita GA4030K Armature Replacement
必要な工具と部品
  1. Makita GA4030K Armature Replacement, Disk Cover: 手順 1、 1の画像 1
    • Check for the provided lock nut wrench. This is used for loosening the piece that keeps the disk and cover attached.
  2. Makita GA4030K Armature Replacement: 手順 2、 1の画像 1
    • Unscrew the handle unit until it is removed completely.
  3. Makita GA4030K Armature Replacement: 手順 3、 2の画像 1 Makita GA4030K Armature Replacement: 手順 3、 2の画像 2
    • Hold the black switch located on the front casing.
    • Still holding the switch, use the lock nut wrench to loosen the silver disk holding everything in place.
    • Once loose, remove the silver disk and/or your grinding disk.
  4. Makita GA4030K Armature Replacement: 手順 4、 2の画像 1 Makita GA4030K Armature Replacement: 手順 4、 2の画像 2
    • Use a Phillips #02 screwdriver to remove the 15 mm pan head screw that holds the cover in place.
    • Remove the cover by lining up the knob on the cover with the notch in face plate.
  5. Makita GA4030K Armature Replacement, Back Cover: 手順 5、 2の画像 1 Makita GA4030K Armature Replacement, Back Cover: 手順 5、 2の画像 2
    • Unscrew the 20 mm tapping screw using a Philips #02 screwdriver.
  6. Makita GA4030K Armature Replacement: 手順 6、 1の画像 1
    • Slide the back cover down the power cable.
  7. Makita GA4030K Armature Replacement, Armature: 手順 7、 2の画像 1 Makita GA4030K Armature Replacement, Armature: 手順 7、 2の画像 2
    • Use a spudger to gently move the brush holder coil to the side.
    • There are two brushes that are secured by two separate brush holders, one on each side.
  8. Makita GA4030K Armature Replacement: 手順 8、 2の画像 1 Makita GA4030K Armature Replacement: 手順 8、 2の画像 2
    • Using a metal spudger, remove both carbon brushes (one on each side) by their copper cabling.
  9. Makita GA4030K Armature Replacement: 手順 9、 3の画像 1 Makita GA4030K Armature Replacement: 手順 9、 3の画像 2 Makita GA4030K Armature Replacement: 手順 9、 3の画像 3
    • Use a Phillips #2 screwdriver to remove the four 20 mm tapping screws that hold the armature assembly in place.
    • Remove the armature assembly
  10. Makita GA4030K Armature Replacement: 手順 10、 2の画像 1 Makita GA4030K Armature Replacement: 手順 10、 2の画像 2
    • Unscrew the four 10 mm tapping screws holding the faceplate using a Phillips #02 screwdriver.
    • Remove the faceplate.
  11. Makita GA4030K Armature Replacement: 手順 11、 2の画像 1 Makita GA4030K Armature Replacement: 手順 11、 2の画像 2
    • Hold the highlighted nut with a size 10 wrench. Unscrew by turning the armature and holding the nut in place.
    • The nut may be difficult to remove.
  12. Makita GA4030K Armature Replacement: 手順 12、 1の画像 1
    • Remove the armature.
終わりに
5 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Laura Ann Jagels
メンバー登録日: 04/01/15
490 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 12-5, Lancaster Spring 2015 Cal Poly, Team 12-5, Lancaster Spring 2015人のメンバー
CPSU-LANCASTER-S15S12G5
4 メンバー
13のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 15
今までの合計 3,460
