はじめに
Follow this guide to remove and replace a worn out clutch drum for a Makita chainsaw.
Some images in this guide may show the chain brake cover removed. You do not need to remove the chain brake cover for this procedure.
Optional tools:
- Chainsaw scrench
必要な工具と部品
Use a 13 mm socket to remove the two nuts securing the sprocket guard plate.
If the chainsaw has a chain and guide bar installed, follow the manufacturer's instructions and remove them before proceeding.
Pull the hand guard towards the tubular handle until you hear a click to release the chain brake.
Use a small flathead screwdriver or snap ring pliers to pry and remove the stop ring from the axle.
2 の人々がこのガイドを完成させました。
