メインコンテンツにスキップ
Maisto Rock Crawler Truck Circuit Board Replacement
必要な工具と部品
  1. Maisto Rock Crawler Truck Circuit Board Replacement, Truck Circuit Board: 手順 1、 2の画像 1 Maisto Rock Crawler Truck Circuit Board Replacement, Truck Circuit Board: 手順 1、 2の画像 2
    • Flip the R/C truck over.
    • To take off the R/C truck top, use the driver and bit PH2 and remove the four 7.7mm Philips screws highlighted.
  2. Maisto Rock Crawler Truck Circuit Board Replacement: 手順 2、 2の画像 1 Maisto Rock Crawler Truck Circuit Board Replacement: 手順 2、 2の画像 2
    • Half way remove the truck top so you can unhinge the antenna from the clips.
    • Remove the R/C truck top completely.
  3. Maisto Rock Crawler Truck Circuit Board Replacement: 手順 3、 1の画像 1
    • Use the Driver and bit J1 to remove the top under-body plate by unscrewing the eight 9.5mm Philips screws.
  4. Maisto Rock Crawler Truck Circuit Board Replacement: 手順 4、 1の画像 1
    • Use the driver and bit J1 and remove the 7.7mm Philips screw highlighted.
  5. Maisto Rock Crawler Truck Circuit Board Replacement: 手順 5、 1の画像 1
    • Take note of which wire is connected at which pin before desoldering. It might help to mark the wires and take a picture.
    • It would be easier to desolder and resolder only one component at a time.
    • Use the soldering iron to desolder all the wires connected to the circuit board.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
kevin
メンバー登録日: 02/10/16
874 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 1-2, Sullivan Spring 2016 USF Tampa, Team 1-2, Sullivan Spring 2016人のメンバー
USFT-SULLIVAN-S16S1G2
3 メンバー
6のガイドは作成済み
9 件のコメント
Can you do anything to it to make it stronger are powerful
Matt John - 返信
Yes put a board from a nikko or ez tec in it. The 9.6 volt is the one to find and wire the motors to the single motor output. I think u have to wire one backwards to get both going right way
Mike - 返信
My rc car is not responding to left or right signals from remote.
CAN I got any help on this
pankaj kapatia - 返信
Can any one help as my rc rock crawler is not turning left or right
pankaj kapatia - 返信
did you use biger voltage than normal? because it sound like that. i think your’s car has brokened ic-component.
mattilajanne - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 30
今までの合計 5,442
