メインコンテンツにスキップ
Magic Bullet NutriBullet Rubber Gasket Replacement
必要な工具と部品
  1. Magic Bullet NutriBullet Rubber Gasket Replacement, Rubber Gasket: 手順 1、 1の画像 1
    • Separate the blending blade lid from the cup.
  2. Magic Bullet NutriBullet Rubber Gasket Replacement: 手順 2、 2の画像 1 Magic Bullet NutriBullet Rubber Gasket Replacement: 手順 2、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using tweezers, grab the gasket at the indented lip which is located on the side of the blending blade.
    • Slowly pry the rubber gasket up.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Geary Yu
メンバー登録日: 01/22/15
1,217 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 19-8, Maness Winter 2015 Cal Poly, Team 19-8, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S19G8
4 メンバー
10のガイドは作成済み
10 件のコメント
The trouble is, this process doesn't work in reverse order as the gasket keeps popping up where you are not applying the pressure. You could do this all day and I'm sure it would be great therapy for OCD.
lizzywade888 - 返信
I want to replace the rubber gasket. My trouble is I can't find a gasket that states it will fit this model. magic Bullet NUTRIBULLET model number NB-WL007-02 Can you tell me where to purchase this? Thanks!
Marcia Sikes
today_first@cox.net
todayfirst - 返信
My understanding is that if it's leaking all the way into the base and not out the sides, it's likely not the main gasket (a faulty one of these would probably cause it to leak out the sides). This is a really good video that explains how to remove the blade and replace the washers that act as gaskets to stop liquid from dripping straight through the center/blade area.
https://www.youtube.com/watch?v=n0fiNRwh...
Tracy Hamilton - 返信
lizzywad is correct. The %#*@ thing wont stay in, it keeps popping out.  What else can be done?
deborah blair - 返信
The gasket in the Nutribullet has disappeared and I think it was blended into the fruit and veg . I drank half of it before I discovered it. I cannot find out if it is toxic or not. Geraldine
geraldine p - 返信
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 57
過去 30 日: 222
今までの合計 34,148
