メインコンテンツにスキップ
Magic Bullet NutriBullet Power Cord Replacement
必要な工具と部品
  1. Magic Bullet NutriBullet Power Cord Replacement, Power Cord: 手順 1、 2の画像 1 Magic Bullet NutriBullet Power Cord Replacement, Power Cord: 手順 1、 2の画像 2
    • Before beginning, make sure the device is unplugged.
    • With a Phillips head #2 screwdriver, begin unscrewing the four 10mm screws located on the bottom of the power base.
  2. Magic Bullet NutriBullet Power Cord Replacement: 手順 2、 1の画像 1
    • Once the screws are removed, pull the plastic base up gently.
    • Once the plastic base is removed, there is a fan located in the center of the powerbase. Make sure the cord does not get caught or frayed by the fan.
  3. Magic Bullet NutriBullet Power Cord Replacement: 手順 3、 1の画像 1
    • Gently lift the power cord from its side slot and place it to the side.
  4. Magic Bullet NutriBullet Power Cord Replacement: 手順 4、 2の画像 1 Magic Bullet NutriBullet Power Cord Replacement: 手順 4、 2の画像 2
    • With the Phillips head #2 screwdriver, remove the two 10mm screws that secure the white bracket.
    • The white safety bracket holds the cord down. After removing it, the cord will be free.
  5. Magic Bullet NutriBullet Power Cord Replacement: 手順 5、 1の画像 1
    • After removing the gray base and silver casing, the wires will now be free and you will have easy access to them.
    • Gently pull out the two plastic covers at the end of the wires.
  6. Magic Bullet NutriBullet Power Cord Replacement: 手順 6、 1の画像 1
    • Use tape or clamps to hold the wires together for an easy soldering experience.
    • Using a soldering iron, solder your new wire to the red wire.
終わりに
Since this guide replacement requires cutting wires, if you want to reassemble this device, you must first re-solder new wires before following the steps backwards to reassemble the device.
3 の人々がこのガイドを完成させました。
作成者
13人の作成者と共同で作成されました。
Geary Yu
メンバー登録日: 01/22/15
1,268 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 19-8, Maness Winter 2015 Cal Poly, Team 19-8, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S19G8
4 メンバー
13のガイドは作成済み
7件のガイドコメント
where am I going to be the magic bullet repair
Or
there a service center here in the philippines?
Thank u.
florentinokarenjoy24 - 返信
Is there a service centre in Singapore?
I just bought the gadget in Melbourne (from Harvey Norman Nunawarding) last week. We used it yesterday but after one round of spinning, gadget went dead.
What could go round and to fix it at home?
Michael Lee - 返信
Can I plug the Magic Bullet in 220v?
Sovelita Tenerife - 返信
Where can I get a replacement cable from?
victoria hatton - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 26
過去 30 日: 122
今までの合計 16,593
