はじめに
If you notice any sharp, moving components outside of your NutriBullet base, then use this replacement guide to learn how to remove and replace the base.
必要な工具と部品
Once the screws are removed, use slight tension to pull the plastic base up.
2 の人々がこのガイドを完成させました。
3 件のコメント
With a lot of force can’t get bottom of even 4 screws removed Bullet don’t work anymore may be a piece of junk now
Where can you buy the base to replace?
