メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
If you notice any sharp, moving components outside of your NutriBullet base, then use this replacement guide to learn how to remove and replace the base.
パーツ
パーツは指定されていません。
  1. Unplug the device from the wall and turn the powerbase upside down.
    • Unplug the device from the wall and turn the powerbase upside down.
  2. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Unscrew the four 10mm screws located on the bottom of the powerbase using the Phillips Head #2 Screwdriver. Unscrew the four 10mm screws located on the bottom of the powerbase using the Phillips Head #2 Screwdriver.
    • Unscrew the four 10mm screws located on the bottom of the powerbase using the Phillips Head #2 Screwdriver.
  4. Once the screws are removed, use slight tension to pull the plastic base up.
    • Once the screws are removed, use slight tension to pull the plastic base up.
    • Make sure the cord does not get caught or frayed by the fan, which is located in the center of the power base.
終わりに
Angela Wong
メンバー登録日: 2015年01月22日
826 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 19-8, Maness Winter 2015 Cal Poly, Team 19-8, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S19G8
4 メンバー
7のガイドは作成済み
3 件のコメント
So far it was easy! Yeah!
Elaine - 返信
With a lot of force can’t get bottom of even 4 screws removed Bullet don’t work anymore may be a piece of junk now
Tommy Simpson - 返信
Where can you buy the base to replace?
Anne-Christine von Wetter - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 17
過去 30 日: 73
今までの合計 5,743
