メインコンテンツにスキップ
パーツ
パーツは指定されていません。
  1. Flip your device with back panel facing up.
    • Flip your device with back panel facing up.
  2. Unscrew four  Phillips #0 screws from the back panel. Unscrew four  Phillips #0 screws from the back panel. Unscrew four  Phillips #0 screws from the back panel.
    • Unscrew four Phillips #0 screws from the back panel.
  3. Unscrew two Phillips #0 screws from the back panel. Unscrew two Phillips #0 screws from the back panel.
    • Unscrew two Phillips #0 screws from the back panel.
  4. Use a plastic opening tool to pop the right side of the panel. Use a plastic opening tool to pop the right side of the panel.
    • Use a plastic opening tool to pop the right side of the panel.
  5. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  6. Lifting the back panel too quickly or forcefully may damage the speaker cable and battery cable, which are still attached underneath.
    • Lifting the back panel too quickly or forcefully may damage the speaker cable and battery cable, which are still attached underneath.
    • Gently lift up the back panel.
  7. Remove the tape. Unplug the cable for the speaker. Unplug the cable for the speaker.
    • Remove the tape.
    • Unplug the cable for the speaker.
  8. Remove the cable of the battery. Tape removal is not necessary. Tape removal is not necessary.
    • Remove the cable of the battery.
    • Tape removal is not necessary.
  9. Place the back panel gently on the table.
    • Place the back panel gently on the table.
  10. Unscrew the left and the right screws using the ifixit screwdriver. Unscrew the left and the right screws using the ifixit screwdriver.
    • Unscrew the left and the right screws using the ifixit screwdriver.
  11. Now that you removed the screws, you can finally replace the speaker.
    • Now that you removed the screws, you can finally replace the speaker.
まとめ
ある他の人がこのガイドを完成しました。
Giovanni
メンバー登録日: 2016年10月18日
313 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 1-5, Catania Fall 2016 UMass Dartmouth, Team 1-5, Catania Fall 2016人のメンバー
UMASSD-CATANIA-F16S1G5
3 メンバー
7のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 63
