メインコンテンツにスキップ
はじめに
If your device won't turn on , you can access or replace the battery by using this guide. Also , make sure you have clean open place to work with. Make sure you have all the tools including the glue, which holds the battery to the panel.
パーツ
パーツは指定されていません。
  1. Flip your device with back panel facing up.
    • Flip your device with back panel facing up.
  2. Unscrew four  Phillips #0 screws from the back panel. Unscrew four  Phillips #0 screws from the back panel. Unscrew four  Phillips #0 screws from the back panel.
    • Unscrew four Phillips #0 screws from the back panel.
  3. Unscrew two Phillips #0 screws from the back panel. Unscrew two Phillips #0 screws from the back panel.
    • Unscrew two Phillips #0 screws from the back panel.
  4. Android 修理キット
    A new screen or battery is one kit away.
    ショップを見る
    Android 修理キット
    ショップを見る
  5. Use a plastic opening tool to pop the right side of the panel. Use a plastic opening tool to pop the right side of the panel.
    • Use a plastic opening tool to pop the right side of the panel.
  6. Lifting the back panel too quickly or forcefully may damage the speaker cable and battery cable, which are still attached underneath.
    • Lifting the back panel too quickly or forcefully may damage the speaker cable and battery cable, which are still attached underneath.
    • Gently lift up the back panel.
  7. Remove the tape. Unplug the cable for the speaker. Unplug the cable for the speaker.
    • Remove the tape.
    • Unplug the cable for the speaker.
  8. Remove the cable of the battery. Tape removal is not necessary. Tape removal is not necessary.
    • Remove the cable of the battery.
    • Tape removal is not necessary.
  9. Place the back panel gently on the table.
    • Place the back panel gently on the table.
  10. Remove the battery by using the IFIXIT plastic tool.
    • Remove the battery by using the IFIXIT plastic tool.
    • Battery is held by glue to the panel.
    • Remember to glue the new battery with the panel to keep it secure..
まとめ
Umar siddique
メンバー登録日: 2016年10月25日
201 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 1-5, Catania Fall 2016 UMass Dartmouth, Team 1-5, Catania Fall 2016人のメンバー
UMASSD-CATANIA-F16S1G5
3 メンバー
7のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 183
