メインコンテンツにスキップ
Magellan RoadMate 5120-LMTX Battery Replacement
必要な工具と部品
  1. Magellan RoadMate 5120-LMTX Battery Replacement, Back Cover: 手順 1、 3の画像 1 Magellan RoadMate 5120-LMTX Battery Replacement, Back Cover: 手順 1、 3の画像 2 Magellan RoadMate 5120-LMTX Battery Replacement, Back Cover: 手順 1、 3の画像 3
    • Power off the Magellan RoadMate before beginning.
    • Remove the six 5mm Phillips #00 screws from the back of device.
  2. Magellan RoadMate 5120-LMTX Battery Replacement: 手順 2、 3の画像 1 Magellan RoadMate 5120-LMTX Battery Replacement: 手順 2、 3の画像 2 Magellan RoadMate 5120-LMTX Battery Replacement: 手順 2、 3の画像 3
    • Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard.
    • Do not fully open the back cover or you risk damaging the speaker wire.
    • Use a spudger to disconnect the speaker connection from the motherboard.
  3. Magellan RoadMate 5120-LMTX Battery Replacement, Battery: 手順 3、 2の画像 1 Magellan RoadMate 5120-LMTX Battery Replacement, Battery: 手順 3、 2の画像 2
    • Run the tip of a spudger between the battery and the housing to loosen the double-sided tape holding the battery in.
    • Still using the spudger tool, pry the battery from the housing.
    • If you damage the tape while trying to remove the battery, you can replace it with any double-sided tape.
  4. Magellan RoadMate 5120-LMTX Battery Replacement: 手順 4、 3の画像 1 Magellan RoadMate 5120-LMTX Battery Replacement: 手順 4、 3の画像 2 Magellan RoadMate 5120-LMTX Battery Replacement: 手順 4、 3の画像 3
    • Pull the edge of the tape up to remove the tape that holds the battery wire to the motherboard.
    • There is a clear rectangular adhesive strip that also needs to be removed with the pointy end of a spudger.
    • Slowly pull the connection from the motherboard.
    • Do not pull too hard or you will risk damaging the wires.
終わりに
作成者
3人の作成者と共同で作成されました。
Steven Prout
メンバー登録日: 10/08/16
231 ポイント
2のガイドは作成済み
チーム
IUPUI, Team 4-4, Wilson Fall 2016 IUPUI, Team 4-4, Wilson Fall 2016人のメンバー
IUPUI-WILSON-F16S4G4
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 14
今までの合計 497
