メインコンテンツにスキップ
Magellan RoadMate 5120-LMTX Antenna Replacement
必要な工具と部品
  1. Magellan RoadMate 5120-LMTX Antenna Replacement, Back Cover: 手順 1、 3の画像 1 Magellan RoadMate 5120-LMTX Antenna Replacement, Back Cover: 手順 1、 3の画像 2 Magellan RoadMate 5120-LMTX Antenna Replacement, Back Cover: 手順 1、 3の画像 3
    • Power off the Magellan RoadMate before beginning.
    • Remove the six 5mm Phillips #00 screws from the back of device.
  2. Magellan RoadMate 5120-LMTX Antenna Replacement: 手順 2、 3の画像 1 Magellan RoadMate 5120-LMTX Antenna Replacement: 手順 2、 3の画像 2 Magellan RoadMate 5120-LMTX Antenna Replacement: 手順 2、 3の画像 3
    • Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard.
    • Do not fully open the back cover or you risk damaging the speaker wire.
    • Use a spudger to disconnect the speaker connection from the motherboard.
  3. Magellan RoadMate 5120-LMTX Antenna Replacement, Motherboard: 手順 3、 3の画像 1 Magellan RoadMate 5120-LMTX Antenna Replacement, Motherboard: 手順 3、 3の画像 2 Magellan RoadMate 5120-LMTX Antenna Replacement, Motherboard: 手順 3、 3の画像 3
    • There will be two 5mm Phillips #00 screws that need to be removed from the motherboard.
  4. Magellan RoadMate 5120-LMTX Antenna Replacement: 手順 4、 3の画像 1 Magellan RoadMate 5120-LMTX Antenna Replacement: 手順 4、 3の画像 2 Magellan RoadMate 5120-LMTX Antenna Replacement: 手順 4、 3の画像 3
    • Some devices may have a piece of tape or plastic over the ribbon cable latch. If your device has this, remove it before continuing.
    • Carefully lift the black ribbon cable latch upwards with a spudger or other similar tool.
    • Once the ribbon cable latch is opened, insert the pointed end of the spudger, or other similar tool, underneath the ribbon cable.
    • Slowly pull out the ribbon cable in a straight, flat motion with respect to the latch.
  5. Magellan RoadMate 5120-LMTX Antenna Replacement: 手順 5、 2の画像 1 Magellan RoadMate 5120-LMTX Antenna Replacement: 手順 5、 2の画像 2
    • Be careful not to touch any of the electrical components on the motherboard as damage may ensue.
    • Carefully lift the motherboard out of the plastic housing by the edges while guiding the ribbon cable through the slot.
    • Store the motherboard on a safe non-conductive surface, preferably an anti-static mat.
  6. Magellan RoadMate 5120-LMTX Antenna Replacement, Antenna: 手順 6、 2の画像 1 Magellan RoadMate 5120-LMTX Antenna Replacement, Antenna: 手順 6、 2の画像 2
    • Remove the two 2.4mm Phillips #00 screws that hold the antenna to the motherboard.
  7. Magellan RoadMate 5120-LMTX Antenna Replacement: 手順 7、 3の画像 1 Magellan RoadMate 5120-LMTX Antenna Replacement: 手順 7、 3の画像 2 Magellan RoadMate 5120-LMTX Antenna Replacement: 手順 7、 3の画像 3
    • Flip the motherboard over and locate the soldered antenna connection.
    • Melt the existing solder with the tip of your soldering iron while gently pulling on the antenna. The antenna should come off easily.
    • When reassembling your device, attach your new antenna to the motherboard using the two 2.4mm Phillips #00 screws before soldering. This will help to align the parts properly and make them easier to solder.
終わりに
To reassemble your device, follow all instructions before soldering step in reverse order.
作成者
3人の作成者と共同で作成されました。
Steven Prout
メンバー登録日: 10/08/16
231 ポイント
2のガイドは作成済み
チーム
IUPUI, Team 4-4, Wilson Fall 2016 IUPUI, Team 4-4, Wilson Fall 2016人のメンバー
IUPUI-WILSON-F16S4G4
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 191
