はじめに
If your Magellan RoadMate is experiencing positioning issues it may have a faulty GPS antenna. Here are the steps for replacing your Magellan RoadMate 5120-LMTX GPS Antenna. This replacement does involve a very simple soldering of a connection.
必要な工具と部品
There will be two 5mm Phillips #00 screws that need to be removed from the motherboard.
Some devices may have a piece of tape or plastic over the ribbon cable latch. If your device has this, remove it before continuing.
Carefully lift the black ribbon cable latch upwards with a spudger or other similar tool.
Once the ribbon cable latch is opened, insert the pointed end of the spudger, or other similar tool, underneath the ribbon cable.
Slowly pull out the ribbon cable in a straight, flat motion with respect to the latch.
To reassemble your device, follow all instructions before soldering step in reverse order.
