メインコンテンツにスキップ
Magellan RoadMate 2120T-LM Motherboard Replacement
必要な工具と部品
  1. Magellan RoadMate 2120T-LM Motherboard Replacement, Battery: 手順 1、 3の画像 1 Magellan RoadMate 2120T-LM Motherboard Replacement, Battery: 手順 1、 3の画像 2 Magellan RoadMate 2120T-LM Motherboard Replacement, Battery: 手順 1、 3の画像 3
    • Turn the GPS over on its backside and remove the six 3 mm Phillips #1 screws.
  2. Magellan RoadMate 2120T-LM Motherboard Replacement: 手順 2、 2の画像 1 Magellan RoadMate 2120T-LM Motherboard Replacement: 手順 2、 2の画像 2
    • Pry up on back panel with black spudger
  3. Magellan RoadMate 2120T-LM Motherboard Replacement: 手順 3、 1の画像 1
    • Disconnect battery and speaker cables from the motherboard at indicated places.
  4. Magellan RoadMate 2120T-LM Motherboard Replacement: 手順 4、 1の画像 1
    • Use a spudger to remove the battery from the back panel.
    • If at all possible, please try to use a regular nylon spudger before resorting to a metal spudger. Metal spudgers are much sharper, and have the potential to accidentally pierce the battery.
    • There is a strong adhesive holding the battery to the back panel.
    • This step is not a prerequisite for replacement of other components.
  5. Magellan RoadMate 2120T-LM Motherboard Replacement, Motherboard: 手順 5、 1の画像 1
    • Remove the four 3 mm Phillips #1 screws from the motherboard.
    • In the picture three out of four screws have already been removed.
  6. Magellan RoadMate 2120T-LM Motherboard Replacement: 手順 6、 2の画像 1 Magellan RoadMate 2120T-LM Motherboard Replacement: 手順 6、 2の画像 2
    • Remove black tape covering connection ribbon for touch-screen
  7. Magellan RoadMate 2120T-LM Motherboard Replacement: 手順 7、 3の画像 1 Magellan RoadMate 2120T-LM Motherboard Replacement: 手順 7、 3の画像 2 Magellan RoadMate 2120T-LM Motherboard Replacement: 手順 7、 3の画像 3
    • Pull up on the brown tab holding down the ribbon.
    • In this picture the brown tab has already been lifted.
    • Lift up on the motherboard and remove it from device.
終わりに
作成者
2人の作成者と共同で作成されました。
John Doe
メンバー登録日: 01/12/16
503 ポイント
4のガイドは作成済み
チーム
Eastern Washington University, Team 1-5, Rowley Winter 2016 Eastern Washington University, Team 1-5, Rowley Winter 2016人のメンバー
EWU-ROWLEY-W16S1G5
2 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 210
