メインコンテンツにスキップ
Magellan RoadMate 1440 Battery Replacement
必要な工具と部品
  1. Magellan RoadMate 1440 Battery Replacement, Magellan RoadMate 1440 Back Cover Disassembly: 手順 1、 1の画像 1
    • Place the GPS with the screen facing down.
  2. Magellan RoadMate 1440 Battery Replacement: 手順 2、 2の画像 1 Magellan RoadMate 1440 Battery Replacement: 手順 2、 2の画像 2
    • Remove the four 4.2 mm screws on the back cover of the device using a Phillips #0 screwdriver.
  3. Magellan RoadMate 1440 Battery Replacement: 手順 3、 2の画像 1 Magellan RoadMate 1440 Battery Replacement: 手順 3、 2の画像 2
    • Remove the two 4.2mm screws at the bottom of the device using a Phillips #0 screwdriver.
  4. Magellan RoadMate 1440 Battery Replacement: 手順 4、 3の画像 1 Magellan RoadMate 1440 Battery Replacement: 手順 4、 3の画像 2 Magellan RoadMate 1440 Battery Replacement: 手順 4、 3の画像 3
    • Insert the black spudger into the crease in the side of the GPS.
    • Move the end of the spudger down to break the seal between the two plastic shells.
    • Continue doing this along each side of the GPS to ensure a smooth removal.
  5. Magellan RoadMate 1440 Battery Replacement: 手順 5、 3の画像 1 Magellan RoadMate 1440 Battery Replacement: 手順 5、 3の画像 2 Magellan RoadMate 1440 Battery Replacement: 手順 5、 3の画像 3
    • Fully separate the two sides of the case.
    • Remove the tape on the battery wires and the tape on the speaker wires.
  6. Magellan RoadMate 1440 Battery Replacement, Battery: 手順 6、 2の画像 1 Magellan RoadMate 1440 Battery Replacement, Battery: 手順 6、 2の画像 2
    • Use the black spudger to break the seal between the adhesive and battery. Use the same spudger to continue to pry the battery from the backing
    • This may be a little tough to separate the battery and the adhesive
  7. Magellan RoadMate 1440 Battery Replacement: 手順 7、 2の画像 1 Magellan RoadMate 1440 Battery Replacement: 手順 7、 2の画像 2
    この手順で使用する道具:
    購入する
    • Lift the battery from the device
    • Once the battery is free from the adhesive, remove the piece of tape with a pair of tweezers that is covering the connection of the battery to the motherboard.
  8. Magellan RoadMate 1440 Battery Replacement: 手順 8、 2の画像 1 Magellan RoadMate 1440 Battery Replacement: 手順 8、 2の画像 2
    • Unplug the battery from the mother board by pulling back the clips and pulling the wires away from the motherboards receptacle
    • It is important for your and the device's safety to remove the battery before continuing with any other part removals.
    • It is not necessary to separate the red and white wires from the battery. A replacement battery pack will come with similar wires already attached.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Jeremy Johnson
メンバー登録日: 03/21/16
201 ポイント
2のガイドは作成済み
チーム
Clemson, Team 7-3, Benson Spring 2016 Clemson, Team 7-3, Benson Spring 2016人のメンバー
CLEM-BENSON-S16S7G3
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 13
今までの合計 808
