メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
A guide to accessing the RoadMate's display.
パーツ
パーツは指定されていません。
  1. Remove the four rubber caps from the back by using the Phillips #00 screwdriver. Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
    • Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
  2. Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
    • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
  3. Remove the back cover from the device by separating the back cover along its seam. Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
    • Remove the back cover from the device by separating the back cover along its seam.
    • Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
  4. Pull the speaker cord, horizontally, by its base, away from the motherboard. When reassembling, make sure that you plug the terminal in the same way.  The black wire should be on the side farthest from the battery.
    • Pull the speaker cord, horizontally, by its base, away from the motherboard.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
  5. 今あるものを使い続けましょう
    オールインワインキットで安く修理して、節約しましょう。
    iPhone 修理キットを見る
    今あるものを使い続けましょう
    iPhone 修理キットを見る
  6. Remove the two screws on that are located on opposite sides of the board.
    • Remove the two screws on that are located on opposite sides of the board.
  7. Lift up the circuit board and disconnect the GPS wire, pulling horizontally from its connector port.
    • Lift up the circuit board and disconnect the GPS wire, pulling horizontally from its connector port.
  8. Peel back the tape securing the display connector to the logic board. Peel back the tape securing the display connector to the logic board.
    • Peel back the tape securing the display connector to the logic board.
  9. Remove the display connector from the device.
    • Remove the display connector from the device.
    • Do not pull on the cable because you may damage it. Instead, try to pull as closely as you can to the plug.
  10. Carefully flip the circuit board out so you can get to the sensor easily. Remove the tape holding the sensor to the display and take out the sensor.
    • Carefully flip the circuit board out so you can get to the sensor easily.
    • Remove the tape holding the sensor to the display and take out the sensor.
  11. Undo the 4 clasps holding the display in place. Pop the display from the front cover. Pop the display from the front cover.
    • Undo the 4 clasps holding the display in place.
    • Pop the display from the front cover.
終わりに
ある他の人がこのガイドを完成しました。
Ross Light
メンバー登録日: 2010年04月12日
175 ポイント
6のガイドは作成済み
コメント1件
In order to remove the rubber plugs hiding the 4 screws, I found that a straight pin angled into the top of the plug can be used to lift them easily straight out and the plug is unharmed.
With the screws out, the back did not budge. I used the thinest blade screw driver in my jeweler's set to pry the case open and pushed on the plastic catches, one on each side that were holding it closed. They are visible in the photo of the back off.
Jomar - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,356
