メインコンテンツにスキップ
MageGee Key Caps Replacement
必要な工具と部品
  1. MageGee Key Caps Replacement, Key Caps: 手順 1、 1の画像 1
    • Test out which keys are the ones that are sticking and giving you trouble.
    • If you have a lot of keys that stick you might want to take note of which ones they or, or alternatively replace your entire keyboard's key caps.
  2. MageGee Key Caps Replacement: 手順 2、 2の画像 1 MageGee Key Caps Replacement: 手順 2、 2の画像 2
    • Remove the damaged keys with a key cap remover by gently pressing onto the desired key cap. Pull gently and the key cap will come off.
    • Make a note of where the keys are located so you know where to replace them.
  3. MageGee Key Caps Replacement: 手順 3、 1の画像 1
    • When removing the keys, remember where each one goes. You can place it in the order it was taken out to help you keep track.
  4. MageGee Key Caps Replacement: 手順 4、 2の画像 1 MageGee Key Caps Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    購入する
    • Check the keyboard for any blockages or obstructions and remove them with tweezers.
    • Alternatively: use your fingers or any other grabbing tools like a pair of small tongs.
  5. MageGee Key Caps Replacement: 手順 5、 1の画像 1
    • Clean the area with a cloth or antibacterial wipe to remove any debris you might have missed.
    • Remember, water damages electronics so be very careful with this step.
  6. MageGee Key Caps Replacement: 手順 6、 1の画像 1
    • Check your removed key caps to see if they are still functional, if not, you may want to get additional key caps to replace the old ones.
  7. MageGee Key Caps Replacement: 手順 7、 1の画像 1
    • If your key caps were damaged, take out corresponding new key caps to replace the old damaged ones.
  8. MageGee Key Caps Replacement: 手順 8、 3の画像 1 MageGee Key Caps Replacement: 手順 8、 3の画像 2 MageGee Key Caps Replacement: 手順 8、 3の画像 3
    • Insert the new key caps in by lining it up with the other keys and pressing it gently into the correct place.
  9. MageGee Key Caps Replacement: 手順 9、 1の画像 1
    • Test out your new key caps and double check its functionality.
  10. MageGee Key Caps Replacement: 手順 10、 2の画像 1 MageGee Key Caps Replacement: 手順 10、 2の画像 2
    • Plug in your keyboard and there you have it, a functional mechanical keyboard.
    • If your keyboard is not fixed, it may be a circuit issue which will result in needing your whole keyboard needing to be replaced.
終わりに
Now your keys on your mechanical keyboard should be working as good as new.
作成者
2人の作成者と共同で作成されました。
Lisa Nguyen
メンバー登録日: 06/29/21
181 ポイント
1ガイドが承認済み
チーム
York University, Team S2-G18, Melo-Thaiss Summer 2021 York University, Team S2-G18, Melo-Thaiss Summer 2021人のメンバー
YORK-MELO-THAISS-SU21S2G18
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 32
過去 30 日: 138
今までの合計 3,300
