メインコンテンツにスキップ
Mad Catz Street Fighter IV FightPad Front Case Replacement
必要な工具と部品
  1. Mad Catz Street Fighter IV FightPad Front Case Replacement, Rear and Side Case: 手順 1、 1の画像 1
    • Use tweezers to completely remove the sticker from the rear of controller.
  2. Mad Catz Street Fighter IV FightPad Front Case Replacement: 手順 2、 1の画像 1
    • Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
  3. Mad Catz Street Fighter IV FightPad Front Case Replacement: 手順 3、 2の画像 1 Mad Catz Street Fighter IV FightPad Front Case Replacement: 手順 3、 2の画像 2
    • Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
    • Use the plastic opening tool to pry the two cases apart.
  4. Mad Catz Street Fighter IV FightPad Front Case Replacement: 手順 4、 2の画像 1 Mad Catz Street Fighter IV FightPad Front Case Replacement: 手順 4、 2の画像 2
    • Remove the two rubber side grips.
  5. Mad Catz Street Fighter IV FightPad Front Case Replacement, RS-DP-LS Switch: 手順 5、 2の画像 1 Mad Catz Street Fighter IV FightPad Front Case Replacement, RS-DP-LS Switch: 手順 5、 2の画像 2
    • Locate RS-DP-LS switch.
    • Pull upwards on the switch to remove it.
  6. Mad Catz Street Fighter IV FightPad Front Case Replacement, Circuit Board: 手順 6、 1の画像 1
    • Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
  7. Mad Catz Street Fighter IV FightPad Front Case Replacement: 手順 7、 3の画像 1 Mad Catz Street Fighter IV FightPad Front Case Replacement: 手順 7、 3の画像 2 Mad Catz Street Fighter IV FightPad Front Case Replacement: 手順 7、 3の画像 3
    • Hold the controller cable at the area just before it meets the controller and slowly lift upwards to slide it out of its plastic slot and remove the circuit board.
    • Be careful with the wires connected to the circuit board itself as they are thin and delicate.
    • When reassembling the controller, make sure that the bottom plastic piece is fully inserted into its slot before replacing the circuit board.
  8. Mad Catz Street Fighter IV FightPad Front Case Replacement, Buttons: 手順 8、 2の画像 1 Mad Catz Street Fighter IV FightPad Front Case Replacement, Buttons: 手順 8、 2の画像 2
    • Remove the six buttons one by one by gripping the back of each one and pushing on them from the front.
    • Use tweezers to remove the rubber part of the directional pad before you try to remove the shoulder buttons.
    • When reinserting the buttons make sure they are in the correct place and oriented correctly.
  9. Mad Catz Street Fighter IV FightPad Front Case Replacement: 手順 9、 1の画像 1
    • Remove the left and right shoulder buttons by sliding them out of their respective slots.
  10. Mad Catz Street Fighter IV FightPad Front Case Replacement, Front Case: 手順 10、 2の画像 1 Mad Catz Street Fighter IV FightPad Front Case Replacement, Front Case: 手順 10、 2の画像 2
    • Pull the plastic piece out from the bottom of the controller.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Eric
メンバー登録日: 09/26/12
117 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 1-7, Propen Fall 2012 Cal Poly, Team 1-7, Propen Fall 2012人のメンバー
CPSU-PROPEN-F12S1G7
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,449
