メインコンテンツにスキップ
Mad Catz Street Fighter IV FightPad Circuit Board Replacement
必要な工具と部品
  1. Mad Catz Street Fighter IV FightPad Circuit Board Replacement, Rear and Side Case: 手順 1、 1の画像 1
    • Use tweezers to completely remove the sticker from the rear of controller.
  2. Mad Catz Street Fighter IV FightPad Circuit Board Replacement: 手順 2、 1の画像 1
    • Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
  3. Mad Catz Street Fighter IV FightPad Circuit Board Replacement: 手順 3、 2の画像 1 Mad Catz Street Fighter IV FightPad Circuit Board Replacement: 手順 3、 2の画像 2
    • Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
    • Use the plastic opening tool to pry the two cases apart.
  4. Mad Catz Street Fighter IV FightPad Circuit Board Replacement: 手順 4、 2の画像 1 Mad Catz Street Fighter IV FightPad Circuit Board Replacement: 手順 4、 2の画像 2
    • Remove the two rubber side grips.
  5. Mad Catz Street Fighter IV FightPad Circuit Board Replacement, RS-DP-LS Switch: 手順 5、 2の画像 1 Mad Catz Street Fighter IV FightPad Circuit Board Replacement, RS-DP-LS Switch: 手順 5、 2の画像 2
    • Locate RS-DP-LS switch.
    • Pull upwards on the switch to remove it.
  6. Mad Catz Street Fighter IV FightPad Circuit Board Replacement, Circuit Board: 手順 6、 1の画像 1
    • Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
  7. Mad Catz Street Fighter IV FightPad Circuit Board Replacement: 手順 7、 3の画像 1 Mad Catz Street Fighter IV FightPad Circuit Board Replacement: 手順 7、 3の画像 2 Mad Catz Street Fighter IV FightPad Circuit Board Replacement: 手順 7、 3の画像 3
    • Hold the controller cable at the area just before it meets the controller and slowly lift upwards to slide it out of its plastic slot and remove the circuit board.
    • Be careful with the wires connected to the circuit board itself as they are thin and delicate.
    • When reassembling the controller, make sure that the bottom plastic piece is fully inserted into its slot before replacing the circuit board.
終わりに
ある他の人がこのガイドを完成しました。
作成者
8人の作成者と共同で作成されました。
Jefferson Hsu
メンバー登録日: 09/18/12
411 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 1-7, Propen Fall 2012 Cal Poly, Team 1-7, Propen Fall 2012人のメンバー
CPSU-PROPEN-F12S1G7
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 2,045
