はじめに
This guide will teach you how to remove and replace the rear cover of a Mad Catz Dual Force 2 Pro controller. If you need to repair the controller or access the internals of your controller you will need to remove the rear cover.
必要な工具と部品
Using the Phillips #1 screwdriver, remove the six 7 mm screws from the rear cover.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
