はじめに
Please remember that these controllers are not designed to be repaired so do not be surprised if you need to be rough with it or something was not initially installed correctly. Also, the same kind of screw was used throughout the controller.
  1. Remove the six 7 mm Phillips screws from the rear cover.
    • Remove the six 7 mm Phillips screws from the rear cover.
  2. Remove the back of the controller.
    • Remove the back of the controller.
    • There are no loose items in the controller that can fall out, so you can open it, generally, however you want.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Remove the two 7 mm screws on the closest circuit board.
    • Remove the two 7 mm screws on the closest circuit board.
  5. Lift the closest circuit board away from the motherboard. Be sure you do not tear the ribbon connecting the smaller circuit board to the motherboard.
    • Lift the closest circuit board away from the motherboard.
    • Be sure you do not tear the ribbon connecting the smaller circuit board to the motherboard.
  6. Grip the analog stick you wish to remove and the smaller circuit board or the cover.
    • Grip the analog stick you wish to remove and the smaller circuit board or the cover.
    • Pull the analog stick from the smaller circuit board.
まとめ
Alexander Coyne
メンバー登録日: 2015年01月11日
604 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 7-2, Remmell Winter 2015 USF Tampa, Team 7-2, Remmell Winter 2015人のメンバー
USFT-REMMELL-W15S7G2
4 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 8
今までの合計 263
