メインコンテンツにスキップ
はじめに
Outline what you are going to teach someone how to do.
パーツ
パーツは指定されていません。
  1. Macintosh Powerbook 5300cs Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • The battery compartment is located in the front-right side of the laptop.
  2. Macintosh Powerbook 5300cs Hard Drive Replacement: 手順 2、 1の画像 1
    • To insert the battery, gently slide it into the compartment until it clicks in place.
    • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
  3. Macintosh Powerbook 5300cs Hard Drive Replacement, Keyboard: 手順 3、 1の画像 1
    • With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
  4. Macintosh Powerbook 5300cs Hard Drive Replacement: 手順 4、 2の画像 1 Macintosh Powerbook 5300cs Hard Drive Replacement: 手順 4、 2の画像 2
    • Carefully pull up on the front of the keyboard to pop it out from the case.
    • Then slide the back out so the keyboard becomes nearly free.
  5. Macintosh Powerbook 5300cs Hard Drive Replacement: 手順 5、 3の画像 1 Macintosh Powerbook 5300cs Hard Drive Replacement: 手順 5、 3の画像 2 Macintosh Powerbook 5300cs Hard Drive Replacement: 手順 5、 3の画像 3
    • Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
    • Pull the keyboard out and repair or replace as needed.
  6. Macintosh Powerbook 5300cs Hard Drive Replacement, Hard Drive: 手順 6、 3の画像 1 Macintosh Powerbook 5300cs Hard Drive Replacement, Hard Drive: 手順 6、 3の画像 2 Macintosh Powerbook 5300cs Hard Drive Replacement, Hard Drive: 手順 6、 3の画像 3
    • Remove the front plastic panel of the laptop by carefully lifting it up.
  7. Macintosh Powerbook 5300cs Hard Drive Replacement: 手順 7、 1の画像 1
    • With a Torx #9 screwdriver, remove the three .30 in. screws that hold the metal frame in place.
  8. Macintosh Powerbook 5300cs Hard Drive Replacement: 手順 8、 3の画像 1 Macintosh Powerbook 5300cs Hard Drive Replacement: 手順 8、 3の画像 2 Macintosh Powerbook 5300cs Hard Drive Replacement: 手順 8、 3の画像 3
    • Remove the metal chasis that holds the hard drive.
  9. Macintosh Powerbook 5300cs Hard Drive Replacement: 手順 9、 1の画像 1
    • In order to remove the hard drive, remove the four .22 in. screws circled in red found on both sides of the metal chassis with a Torx #9 screwdriver.
  10. Macintosh Powerbook 5300cs Hard Drive Replacement: 手順 10、 2の画像 1 Macintosh Powerbook 5300cs Hard Drive Replacement: 手順 10、 2の画像 2
    • Pull the hard drive out.
終わりに
2 の人々がこのガイドを完成させました。
Ronan
メンバー登録日: 2011年10月10日
63 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 6-1, Regan Fall 2011 Cal Poly, Team 6-1, Regan Fall 2011人のメンバー
CPSU-REGAN-F11S6G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 1,448
