はじめに
Use this guide to replace the Modem Card.
  1. Orient the computer so the battery is facing you.
    • Orient the computer so the battery is facing you.
    • Slide the gray plastic battery cover to the right.
  2. Pull the battery toward yourself until it is fully detached.
    • Pull the battery toward yourself until it is fully detached.
  3. Orient the computer right side up with the rear facing you.
    • Orient the computer right side up with the rear facing you.
    • Open the Input/Output (I/O) door.
  4. Carefully bend the door into an arch until one of the pins releases from its slot.
    • Carefully bend the door into an arch until one of the pins releases from its slot.
    • Once one of the pins is free, remove the I/O door from the computer.
  5. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  6. Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
    • Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
  7. Use a T8 torx screwdriver to remove the 6.8mm long screw above and to the right of the modem jack.
    • Use a T8 torx screwdriver to remove the 6.8mm long screw above and to the right of the modem jack.
    • Twist counter clockwise to remove the screw.
  8. Use a T10 torx screwdriver to remove the four, 18mm long screws from the lower case.
    • Use a T10 torx screwdriver to remove the four, 18mm long screws from the lower case.
  9. Place your hands on the lower case, just above the I/O panel, and slowly lift the lower case a few inches above the main body of the computer. Release the large, gray interconnect ribbon cable just behind the I/O panel.
    • Place your hands on the lower case, just above the I/O panel, and slowly lift the lower case a few inches above the main body of the computer.
    • Release the large, gray interconnect ribbon cable just behind the I/O panel.
    • Caution: Lower case cannot be fully removed until two plastic clips in the front corners are released. See the following step for details.
  10. Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case. Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
    • Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case.
    • Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
    • Lift the lower case to remove it.
  11. Orient the computer so the ports are facing you.
    • Orient the computer so the ports are facing you.
  12. Locate the Modem Card on the lower case. Use a T8 torx screwdriver to remove the two, 7.7mm long screws from the two corners.
    • Locate the Modem Card on the lower case.
    • Use a T8 torx screwdriver to remove the two, 7.7mm long screws from the two corners.
    • The modem card is an optional component on the Macintosh 165c, and may not be included in all devices.
  13. Lift the modem card directly upward until it releases from the connector.
    • Lift the modem card directly upward until it releases from the connector.
    • If the modem card is difficult to remove, gently jostle it back and forth as you lift up.
まとめ
John
メンバー登録日: 2011年10月12日
70 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 6-3, Regan Fall 2011 Cal Poly, Team 6-3, Regan Fall 2011人のメンバー
CPSU-REGAN-F11S6G3
4 メンバー
12のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 504
