メインコンテンツにスキップ
Macintosh PowerBook 165c Keyboard Replacement
必要な工具と部品
  1. Macintosh PowerBook 165c Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Orient the computer so the battery is facing you.
    • Slide the gray plastic battery cover to the right.
  2. Macintosh PowerBook 165c Keyboard Replacement: 手順 2、 1の画像 1
    • Pull the battery toward yourself until it is fully detached.
  3. Macintosh PowerBook 165c Keyboard Replacement, Input/Output Door: 手順 3、 1の画像 1
    • Orient the computer right side up with the rear facing you.
    • Open the Input/Output (I/O) door.
  4. Macintosh PowerBook 165c Keyboard Replacement: 手順 4、 1の画像 1
    • Carefully bend the door into an arch until one of the pins releases from its slot.
    • Once one of the pins is free, remove the I/O door from the computer.
  5. Macintosh PowerBook 165c Keyboard Replacement, Lower Case: 手順 5、 1の画像 1
    • Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
  6. Macintosh PowerBook 165c Keyboard Replacement: 手順 6、 1の画像 1
    • Use a T8 torx screwdriver to remove the 6.8mm long screw above and to the right of the modem jack.
    • Twist counter clockwise to remove the screw.
  7. Macintosh PowerBook 165c Keyboard Replacement: 手順 7、 1の画像 1
    • Use a T10 torx screwdriver to remove the four, 18mm long screws from the lower case.
  8. Macintosh PowerBook 165c Keyboard Replacement: 手順 8、 2の画像 1 Macintosh PowerBook 165c Keyboard Replacement: 手順 8、 2の画像 2
    • Place your hands on the lower case, just above the I/O panel, and slowly lift the lower case a few inches above the main body of the computer.
    • Release the large, gray interconnect ribbon cable just behind the I/O panel.
    • Caution: Lower case cannot be fully removed until two plastic clips in the front corners are released. See the following step for details.
  9. Macintosh PowerBook 165c Keyboard Replacement: 手順 9、 2の画像 1 Macintosh PowerBook 165c Keyboard Replacement: 手順 9、 2の画像 2
    • Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case.
    • Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
    • Lift the lower case to remove it.
  10. Macintosh PowerBook 165c Keyboard Replacement, Trackball: 手順 10、 2の画像 1 Macintosh PowerBook 165c Keyboard Replacement, Trackball: 手順 10、 2の画像 2
    • Locate the trackball assembly. It is in the upper case and can be identified by a green circuit board.
    • Open the white tab fastener by pulling out on each side. and remove the green and silver ribbon cable.
    • Remove the green and silver ribbon cable by gently pulling it away from the opened tab fastener.
  11. Macintosh PowerBook 165c Keyboard Replacement: 手順 11、 1の画像 1
    • Use a T8 torx screwdriver to remove the six, 6.8mm long screws from the top of the green circuit board.
  12. Macintosh PowerBook 165c Keyboard Replacement: 手順 12、 1の画像 1
    • Remove all four components of the trackball assembly by lifting upward.
    • The four components of the trackball assembly should include: the green circuit board, a metal support, the track ball, and the casing.
  13. Macintosh PowerBook 165c Keyboard Replacement, Keyboard: 手順 13、 2の画像 1 Macintosh PowerBook 165c Keyboard Replacement, Keyboard: 手順 13、 2の画像 2
    • Open the left most white tab fastener in the lower left corner by pulling up on each side.
    • Remove the ribbon cable by gently pulling it away from the opened tab fastener.
  14. Macintosh PowerBook 165c Keyboard Replacement: 手順 14、 2の画像 1 Macintosh PowerBook 165c Keyboard Replacement: 手順 14、 2の画像 2
    • Open the right of the two small, white tab fasteners by pulling up on both sides.
    • Remove the green and silver ribbon cable from the tab fastener.
  15. Macintosh PowerBook 165c Keyboard Replacement: 手順 15、 1の画像 1
    • Use a T8 torx screwdriver to remove the seven, 6.8mm long screws from the metallic panel.
  16. Macintosh PowerBook 165c Keyboard Replacement: 手順 16、 1の画像 1
    • Remove the keyboard by lifting it vertically away from the main body of the computer.
終わりに
作成者
5人の作成者と共同で作成されました。
Adam
メンバー登録日: 10/12/11
1 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 6-3, Regan Fall 2011 Cal Poly, Team 6-3, Regan Fall 2011人のメンバー
CPSU-REGAN-F11S6G3
4 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 1,017
