メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Macintosh PowerBook 165c Keyboard Replacement
必要な工具と部品
  1. Macintosh PowerBook 165c Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Orient the computer so the battery is facing you.
    • Slide the gray plastic battery cover to the right.
    FixBotに聞いてみる
    コメントを追加
  2. Macintosh PowerBook 165c Keyboard Replacement: 手順 2、 1の画像 1
    • Pull the battery toward yourself until it is fully detached.
    FixBotに聞いてみる
    コメントを追加
  3. Macintosh PowerBook 165c Keyboard Replacement, Input/Output Door: 手順 3、 1の画像 1
    • Orient the computer right side up with the rear facing you.
    • Open the Input/Output (I/O) door.
    FixBotに聞いてみる
    コメントを追加
  4. Macintosh PowerBook 165c Keyboard Replacement: 手順 4、 1の画像 1
    • Carefully bend the door into an arch until one of the pins releases from its slot.
    • Once one of the pins is free, remove the I/O door from the computer.
    FixBotに聞いてみる
    コメントを追加
  5. Macintosh PowerBook 165c Keyboard Replacement, Lower Case: 手順 5、 1の画像 1
    • Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
    FixBotに聞いてみる
    コメントを追加
  6. Macintosh PowerBook 165c Keyboard Replacement: 手順 6、 1の画像 1
    • Use a T8 torx screwdriver to remove the 6.8mm long screw above and to the right of the modem jack.
    • Twist counter clockwise to remove the screw.
    FixBotに聞いてみる
    コメントを追加
  7. Macintosh PowerBook 165c Keyboard Replacement: 手順 7、 1の画像 1
    • Use a T10 torx screwdriver to remove the four, 18mm long screws from the lower case.
    FixBotに聞いてみる
    コメントを追加
  8. Macintosh PowerBook 165c Keyboard Replacement: 手順 8、 2の画像 1 Macintosh PowerBook 165c Keyboard Replacement: 手順 8、 2の画像 2
    • Place your hands on the lower case, just above the I/O panel, and slowly lift the lower case a few inches above the main body of the computer.
    • Release the large, gray interconnect ribbon cable just behind the I/O panel.
    • Caution: Lower case cannot be fully removed until two plastic clips in the front corners are released. See the following step for details.
    FixBotに聞いてみる
    コメントを追加
  9. Macintosh PowerBook 165c Keyboard Replacement: 手順 9、 2の画像 1 Macintosh PowerBook 165c Keyboard Replacement: 手順 9、 2の画像 2
    • Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case.
    • Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
    • Lift the lower case to remove it.
    FixBotに聞いてみる
    コメントを追加
  10. Macintosh PowerBook 165c Keyboard Replacement, Trackball: 手順 10、 2の画像 1 Macintosh PowerBook 165c Keyboard Replacement, Trackball: 手順 10、 2の画像 2
    • Locate the trackball assembly. It is in the upper case and can be identified by a green circuit board.
    • Open the white tab fastener by pulling out on each side. and remove the green and silver ribbon cable.
    • Remove the green and silver ribbon cable by gently pulling it away from the opened tab fastener.
    FixBotに聞いてみる
    コメントを追加
  11. Macintosh PowerBook 165c Keyboard Replacement: 手順 11、 1の画像 1
    • Use a T8 torx screwdriver to remove the six, 6.8mm long screws from the top of the green circuit board.
    FixBotに聞いてみる
    コメントを追加
  12. Macintosh PowerBook 165c Keyboard Replacement: 手順 12、 1の画像 1
    • Remove all four components of the trackball assembly by lifting upward.
    • The four components of the trackball assembly should include: the green circuit board, a metal support, the track ball, and the casing.
    FixBotに聞いてみる
    コメントを追加
  13. Macintosh PowerBook 165c Keyboard Replacement, Keyboard: 手順 13、 2の画像 1 Macintosh PowerBook 165c Keyboard Replacement, Keyboard: 手順 13、 2の画像 2
    • Open the left most white tab fastener in the lower left corner by pulling up on each side.
    • Remove the ribbon cable by gently pulling it away from the opened tab fastener.
    FixBotに聞いてみる
    コメントを追加
  14. Macintosh PowerBook 165c Keyboard Replacement: 手順 14、 2の画像 1 Macintosh PowerBook 165c Keyboard Replacement: 手順 14、 2の画像 2
    • Open the right of the two small, white tab fasteners by pulling up on both sides.
    • Remove the green and silver ribbon cable from the tab fastener.
    FixBotに聞いてみる
    コメントを追加
  15. Macintosh PowerBook 165c Keyboard Replacement: 手順 15、 1の画像 1
    • Use a T8 torx screwdriver to remove the seven, 6.8mm long screws from the metallic panel.
    FixBotに聞いてみる
    コメントを追加
  16. Macintosh PowerBook 165c Keyboard Replacement: 手順 16、 1の画像 1
    • Remove the keyboard by lifting it vertically away from the main body of the computer.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
5人の作成者と共同で作成されました。
Adam
メンバー登録日: 10/12/11
1 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 6-3, Regan Fall 2011 Cal Poly, Team 6-3, Regan Fall 2011人のメンバー
CPSU-REGAN-F11S6G3
4 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 36
今までの合計 1,244
