この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Use this guide to replace the Hard Drive.
必要な工具と部品
Orient the computer so the battery is facing you.
Slide the gray plastic battery cover to the right.
Orient the computer right side up with the rear facing you.
Open the Input/Output (I/O) door.
Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case.
Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
Lift the lower case to remove it.
Locate and lift ram card directly up until connector releases.
Move the card back and forth gently if the connector does not release immediately.
Use T8 torx screwdriver to remove four, 7.7mm long screws from the perimeter of the daughterboard.
Use a T8 torx screwdriver to remove the five, 6.8mm long screws on the drive retainer.
2 の人々がこのガイドを完成させました。
