メインコンテンツにスキップ
Macintosh PowerBook 1400 Series Hard Drive Replacement
必要な工具と部品
  1. Macintosh PowerBook 1400 Series Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Turn the device upside down and then locate the battery latch near the front of the device.
  2. Macintosh PowerBook 1400 Series Hard Drive Replacement: 手順 2、 1の画像 1
    • Slide the latch to the left to release the battery.
  3. Macintosh PowerBook 1400 Series Hard Drive Replacement: 手順 3、 1の画像 1
    • Continue holding the latch then gently pull the battery out of the device.
    • Place the battery in a safe location.
  4. Macintosh PowerBook 1400 Series Hard Drive Replacement, CD-ROM Drive: 手順 4、 1の画像 1
    • Locate the CD-ROM Drive latch.
  5. Macintosh PowerBook 1400 Series Hard Drive Replacement: 手順 5、 1の画像 1
    • Slide the latch to the right to release the CD ROM drive.
  6. Macintosh PowerBook 1400 Series Hard Drive Replacement: 手順 6、 1の画像 1
    • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
    • Place the CD ROM drive in a safe location.
  7. Macintosh PowerBook 1400 Series Hard Drive Replacement, Keyboard: 手順 7、 1の画像 1
    • Locate the speaker cover.
  8. Macintosh PowerBook 1400 Series Hard Drive Replacement: 手順 8、 1の画像 1
    • Press firmly on each end of the speaker cover and slide it to the left.
  9. Macintosh PowerBook 1400 Series Hard Drive Replacement: 手順 9、 1の画像 1
    • Gently lift the speaker cover to remove it.
  10. Macintosh PowerBook 1400 Series Hard Drive Replacement: 手順 10、 1の画像 1
    • Lift the keyboard up from the back using a spudger(wedge side).
  11. Macintosh PowerBook 1400 Series Hard Drive Replacement: 手順 11、 1の画像 1
    • Gently lift the keyboard until only the ribbon cable remains attached.
  12. Macintosh PowerBook 1400 Series Hard Drive Replacement: 手順 12、 1の画像 1
    • Tilt the keyboard away from the screen.
  13. Macintosh PowerBook 1400 Series Hard Drive Replacement: 手順 13、 1の画像 1
    • Locate the six screws that secure the heatsink.
  14. Macintosh PowerBook 1400 Series Hard Drive Replacement: 手順 14、 1の画像 1
    • Remove the six screws from the heatsink using the Philips #1 screwdriver.
  15. Macintosh PowerBook 1400 Series Hard Drive Replacement: 手順 15、 1の画像 1
    • Lift the heatsink from the side closest to the laptop screen.
  16. Macintosh PowerBook 1400 Series Hard Drive Replacement: 手順 16、 1の画像 1
    • Remove the heatsink.
  17. Macintosh PowerBook 1400 Series Hard Drive Replacement: 手順 17、 1の画像 1
    • Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
  18. Macintosh PowerBook 1400 Series Hard Drive Replacement: 手順 18、 1の画像 1
    • Detach the ribbon cable.
  19. Macintosh PowerBook 1400 Series Hard Drive Replacement: 手順 19、 1の画像 1
    • Remove the keyboard.
  20. Macintosh PowerBook 1400 Series Hard Drive Replacement, Hard Drive: 手順 20、 1の画像 1
    • Locate and identify the two screws that attach the hard drive to the computer.
  21. Macintosh PowerBook 1400 Series Hard Drive Replacement: 手順 21、 1の画像 1
    • Remove the screws with a Phillips #0 screwdriver.
  22. Macintosh PowerBook 1400 Series Hard Drive Replacement: 手順 22、 1の画像 1
    • Once the screws are removed, lift up the end of the hard drive using your finger tips.
  23. Macintosh PowerBook 1400 Series Hard Drive Replacement: 手順 23、 1の画像 1
    • Fully lift the hard drive vertically against the side of the computer.
  24. Macintosh PowerBook 1400 Series Hard Drive Replacement: 手順 24、 1の画像 1
    • Push a finger down onto the plastic strap.
  25. Macintosh PowerBook 1400 Series Hard Drive Replacement: 手順 25、 1の画像 1
    • Remove the hard drive from the computer by pushing down on the plastic strap and pulling up on the hard drive.
終わりに
11 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Jeffrey Huntley
メンバー登録日: 04/01/11
248 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 10-39, Forte Spring 2011 Cal Poly, Team 10-39, Forte Spring 2011人のメンバー
CPSU-FORTE-S11S10G39
5 メンバー
6のガイドは作成済み
コメント 1 件
Hi iFixIt thanks for all the details BUT the keyboard can indeed stay in
when changing the hard drive. Just slide it a bit to the right after step
11, the ribbon cble does not take any damage. SO: from step 12 jump
straight to step 20. The heat sink can stay untouched, which i find not
unimportant to mention. Regards, TB75
TB75 - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 36
今までの合計 8,848
