はじめに
The Macintosh Classic is a computer mounted in a simple way but with two different types of screws (Torks and Philips) put in the most unattainable places.
Templates
Model Number: M0420 and M1240
必要な工具と部品
Connect a flat screwdriver to the CRT ground cable (black cable attached to the screw) with an alligator cable.
Slowly push the screwdriver under the red suction cup connected to the CRT and touch the metal part with the screwdriver.
Remove the four screws and pay attention to the two hidden screws.
The Floppy lock and Disk go away easily.
Unscrew the two screws that secure it to the chassis and remove the connected cables.
To reassemble the device, follow these instructions in reverse order.
2 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
