この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Rock out too hard? Use this guide to replace a blown-out rear speaker.
必要な工具と部品
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Remove the following screws from the optical drive side of the rear vent:
Two 10 mm T8 Torx
Two 5.2 mm Phillips
Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
24 の人々がこのガイドを完成させました。
4 件のコメント
Nice tuto ! Helped me so fine.
hi everyone! iʻm about to replace the rear speaker on my late 2009 A1342, but i also need to replace both the left and right speakers as well. would someone please help me out? i hope i donʻt have to pull the logic board (i already did that on my mid 2012 A1284, and it was, ok, but i have more gray hairs now . . .).
