メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
MacBook Unibody Model A1342 Hard Drive Cable Replacement
必要な工具と部品
  1. MacBook Unibody Model A1342 Hard Drive Cable Replacement, Lower Case: 手順 1、 1の画像 1
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
    FixBotに聞いてみる
    コメントを追加
  2. MacBook Unibody Model A1342 Hard Drive Cable Replacement: 手順 2、 3の画像 1 MacBook Unibody Model A1342 Hard Drive Cable Replacement: 手順 2、 3の画像 2 MacBook Unibody Model A1342 Hard Drive Cable Replacement: 手順 2、 3の画像 3
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
    FixBotに聞いてみる
    コメントを追加
  3. MacBook Unibody Model A1342 Hard Drive Cable Replacement, Battery: 手順 3、 1の画像 1
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
    • It may be easier to use your fingernails to lift up on both sides of the connector.
    FixBotに聞いてみる
    コメントを追加
  4. MacBook Unibody Model A1342 Hard Drive Cable Replacement, Hard Drive: 手順 4、 1の画像 1
    • Remove two 11 mm Phillips screws securing the hard drive bracket to the upper case.
    • These screws are captive in the hard drive bracket.
    FixBotに聞いてみる
    コメントを追加
  5. MacBook Unibody Model A1342 Hard Drive Cable Replacement: 手順 5、 1の画像 1
    • Lift the retaining bracket out of the upper case.
    • When putting the bracket back after replacing the drive, it is easy to put in backwards. If it doesn't seat smoothly, then reverse it and try again.
    FixBotに聞いてみる
    コメントを追加
  6. MacBook Unibody Model A1342 Hard Drive Cable Replacement: 手順 6、 3の画像 1 MacBook Unibody Model A1342 Hard Drive Cable Replacement: 手順 6、 3の画像 2 MacBook Unibody Model A1342 Hard Drive Cable Replacement: 手順 6、 3の画像 3
    • Lift the hard drive by its pull tab and pull it away from the upper case, minding the cable still attaching it to the logic board.
    • In some revisions of the MacBook A1342, the hard drive bracket may include two rubber brackets (as highlighted in the second picture.) The correct orientation of the rubber brackets is shown in the third picture.
    FixBotに聞いてみる
    コメントを追加
  7. MacBook Unibody Model A1342 Hard Drive Cable Replacement: 手順 7、 2の画像 1 MacBook Unibody Model A1342 Hard Drive Cable Replacement: 手順 7、 2の画像 2
    • Remove the hard drive cable by pulling its connector straight away from the hard drive.
    FixBotに聞いてみる
    コメントを追加
  8. MacBook Unibody Model A1342 Hard Drive Cable Replacement, Hard Drive Cable: 手順 8、 1の画像 1
    • Remove the 3.1 mm Phillips screw securing the hard drive cable to the upper case.
    FixBotに聞いてみる
    コメントを追加
  9. MacBook Unibody Model A1342 Hard Drive Cable Replacement: 手順 9、 1の画像 1
    • Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
    • Remove the hard drive cable from the upper case.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
19 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Walter Galan
709,855 ポイント
1,203のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 86
今までの合計 22,322
