メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement
必要な工具と部品
    1. MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement, Lower Case: 手順 1、 1の画像 1
      • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
      FixBotに聞いてみる
      コメントを追加
    2. MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement: 手順 2、 3の画像 1 MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement: 手順 2、 3の画像 2 MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement: 手順 2、 3の画像 3
      • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
      • Slightly lift the lower case near the vent opening.
      • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
      • The location of these three clips is shown in the third picture.
      FixBotに聞いてみる
      コメントを追加
    1. MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement, Battery: 手順 3、 1の画像 1
      • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
      • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
      • It may be easier to use your fingernails to lift up on both sides of the connector.
      FixBotに聞いてみる
      コメントを追加
    1. MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement, AirPort/Bluetooth Cable: 手順 4、 2の画像 1 MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement, AirPort/Bluetooth Cable: 手順 4、 2の画像 2
      • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
      • Carefully peel the AirPort/Bluetooth ribbon cable from its channel within the rear speaker assembly.
      FixBotに聞いてみる
      コメントを追加
    2. MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement: 手順 5、 1の画像 1
      • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the right speaker.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
10 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Walter Galan
710,691 ポイント
1,203のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 52
今までの合計 15,367
