メインコンテンツにスキップ
MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement
必要な工具と部品
  1. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement, Lower Case: 手順 1、 1の画像 1
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 手順 2、 3の画像 1 MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 手順 2、 3の画像 2 MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 手順 2、 3の画像 3
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
  3. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement, Battery: 手順 3、 1の画像 1
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
    • It may be easier to use your fingernails to lift up on both sides of the connector.
  4. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement, Rear Vent: 手順 4、 1の画像 1
    • Remove the following screws from the optical drive side of the rear vent:
    • Two 10 mm T8 Torx
    • Two 5.2 mm Phillips
  5. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 手順 5、 1の画像 1
    • Remove the following screws from the port side of rear vent:
    • Two 10 mm T8 Torx
  6. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 手順 6、 1の画像 1
    • Carefully lift the rear vent out of the upper case.
  7. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement, Rear Speaker Assembly: 手順 7、 1の画像 1
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
  8. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 手順 8、 1の画像 1
    • Remove the following screws securing the right speaker assembly to the upper case:
    • One 12 mm Phillips screw.
    • One 3 mm Phillips screw.
  9. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 手順 9、 1の画像 1
    • Remove the single 2.2 mm Phillips screw inserted horizontally into the side of the optical drive.
  10. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 手順 10、 2の画像 1 MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 手順 10、 2の画像 2
    • Pry the AirPort and Bluetooth antenna connectors (3 total) up off the AirPort/Bluetooth card.
    • De-route the long antenna from its channel in the rear speaker housing.
  11. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 手順 11、 1の画像 1
    • Use the flat end of a spudger to pry the rear speaker cable connector up off the logic board.
  12. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 手順 12、 1の画像 1
    • Remove the rear speaker assembly from the upper case.
  13. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 手順 13、 2の画像 1 MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 手順 13、 2の画像 2
    • Carefully peel the AirPort/Bluetooth cable from its channel within the rear speaker assembly.
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable up off the rear speaker.
  14. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 手順 14、 1の画像 1
    • Remove three 3 mm Phillips screws securing the AirPort/Bluetooth board to the rear speaker assembly.
  15. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 手順 15、 1の画像 1
    • Lift the AirPort/Bluetooth board up off the rear speaker assembly.
  16. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Board: 手順 16、 1の画像 1
    • AirPort/Bluetooth board remains.
終わりに
29 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Walter Galan
694,877 ポイント
1,203のガイドは作成済み
3 件のコメント
Terrific guide; no problems, at all! Don't forget you need to add the Wi-Fi service back to the list of services:
1. Go to System Preferences → Network and click the + button to add a service.
2. Select Wi-Fi as the Interface and provide a service name.
For more info, please see http://apple.stackexchange.com/questions....
schmidtjoel - 返信
At Step 11 I accidently pulled the connector off the board incorrectly and it won't fit back on. What is the difficulty level of resoldering this back onto the logic board or should I take it to a professional?
gregpif - 返信
Hello!
Does anyone know where I could find this bt card but with Bt 4.0 LE in order to get handoff and continuity to work on this A1342 Macbook?
Thanks!
junkprotectorvpc - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 46
今までの合計 41,767
