メインコンテンツにスキップ
はじめに
This guide will show you how to remove the hard drive cable from your laptop.
  1. With the case closed, place the Unibody top-side down on a flat surface.
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
  2. The access door should now be raised enough to lift it up and out of the Unibody.
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. Be sure the access door release latch is vertical before proceeding.
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the white plastic tab and pull the battery up and out of the Unibody.
  4. Remove the following eight screws securing the lower case to the chassis:
    • Remove the following eight screws securing the lower case to the chassis:
    • One 3 mm Phillips screw.
    • Four 3.5 mm Phillips screws.
  5. Using both hands, lift and remove the lower case off the upper case.
    • Using both hands, lift and remove the lower case off the upper case.
  6. Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
    • Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
  7. Disconnect the camera cable by pulling the male end straight away from its socket.
    • Disconnect the camera cable by pulling the male end straight away from its socket.
  8. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  9. Use a spudger to pry the optical drive connector straight up off the logic board.
    • Use a spudger to pry the optical drive connector straight up off the logic board.
  10. Remove the two Phillips screws securing the subwoofer to the upper case.
    • Remove the two Phillips screws securing the subwoofer to the upper case.
    • The longer of the two screws is on the right.
  11. The subwoofer is still connected to the right speaker, so don't completely remove it just yet.
    • The subwoofer is still connected to the right speaker, so don't completely remove it just yet.
    • Lift the subwoofer off the optical drive, and set it above the computer.
  12. Remove the two Phillips screws securing the camera cable bracket to the upper case.
    • Remove the two Phillips screws securing the camera cable bracket to the upper case.
    • The leftmost screw may remain captive in the camera cable.
  13. Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
    • Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
  14. Lift the optical drive from its right edge and pull it out of the computer.
    • Lift the optical drive from its right edge and pull it out of the computer.
    • The hard drive cable may become disconnected from the logic board when removing the optical drive. Ensure it is connected during reassembly.
  15. Remove the single Phillips screw securing the hard drive bracket to the upper case.
    • Remove the single Phillips screw securing the hard drive bracket to the upper case.
    • This screw is captive in the hard drive bracket.
  16. Lift the hard drive by its plastic pull tab and remove the freed hard drive bracket.
    • Lift the hard drive by its plastic pull tab and remove the freed hard drive bracket.
  17. Lift the hard drive out of its supports and disconnect the SATA cable by pulling the connector straight away from the hard drive.
    • Lift the hard drive out of its supports and disconnect the SATA cable by pulling the connector straight away from the hard drive.
  18. Remove the four 10.3 mm Phillips screws securing the mid wall to the upper case.
    • Remove the four 10.3 mm Phillips screws securing the mid wall to the upper case.
  19. Lift the mid wall out of the upper case.
    • Lift the mid wall out of the upper case.
  20. Use a spudger to pry the hard drive cable connector straight up off the logic board.
    • Use a spudger to pry the hard drive cable connector straight up off the logic board.
  21. Peel the hard drive cable from the adhesive securing it to the upper case, and maneuver the plastic retaining block out of the upper case. During reassembly, be sure the two pins on top of the plastic retaining block mate to the holes on the underside of the midwall.
    • Peel the hard drive cable from the adhesive securing it to the upper case, and maneuver the plastic retaining block out of the upper case.
    • During reassembly, be sure the two pins on top of the plastic retaining block mate to the holes on the underside of the midwall.
まとめ
19 の人々がこのガイドを完成させました。
Walter Galan
595,749 ポイント
1,203のガイドは作成済み
My mid-2012 MBP MD101LL/A a1278 doesn’t look anything like this, nor does the cable.
RICHARD CHAN - 返信
These instructions are not for the Mid 2012 A1278, but for a much older MacBook Pro. Pretty confusing.
Tor Willy Austerslått - 返信
コメントを追加する
統計データを表示:
過去 24時間: 3
過去 7 日: 27
過去 30 日: 118
今までの合計 38,465
