必要な工具と部品
ビデオの概要
Press the power button. The MacBook won’t turn on.
Plug in the BY-3200 power cable and the input voltage is 20V.
The current reading on the DC Power Supply stays at 0.047A.
In the first place, we used MacBook BY-3200 power cable to observe the change of boot voltage and current. The voltage values related to the boot circuit on the motherboard were found to be normal after measuring. To determine whether the fault was caused by data problems, BY-T200 Data Assistant was used to read and write the data of T2 chip ROM. After rewriting the ROM data of T2 chip, the MacBook could turn on and enter the system. The no power fault has been cleared.
3 件のコメント
Whre can I buy T2 rom original file ?
I have chunky fingers for female & not as strong as I use to be, will try. That iMac was hard enough as it was!
Where can we find this "A1989 T2 ROM original data.bin"?
