必要な工具と部品
If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
