メインコンテンツにスキップ
はじめに
MacBook Pro 17" Unibody 2.2GHz early 2011 Duo
Vibrating noise from new MacBook Pro ?
Rattling fan ? Overheating ?
Give this a try !
  1. I am using Husky screwdrivers HD 74501 U & HD 74502 Y
    • I am using Husky screwdrivers HD 74501 U & HD 74502 Y
  2. Turn your MBP upside down
    • Turn your MBP upside down
  3. Remove the screws from the back cover
    • Remove the screws from the back cover
  4. Carefully open the back cover.
    • Carefully open the back cover.
  5. Remove the dust . I am using  a vacuum cleaner here with a brush.
    • Remove the dust . I am using a vacuum cleaner here with a brush.
  6. Keep your Apple warranty by disconnecting the battery and DO NO TOUCH any electronic parts and chips ! Also touch any metal item to unload the body static.
    • Keep your Apple warranty by disconnecting the battery and DO NO TOUCH any electronic parts and chips ! Also touch any metal item to unload the body static.
    • Keep your Apple warranty and disconnect the battery.
  7. Disconnect the fan from the mainboard. Disconnect the fan from the mainboard. Disconnect the fan from the mainboard.
    • Disconnect the fan from the mainboard.
  8. Remove the 3 screws that  fron the fan fixture.
    • Remove the 3 screws that fron the fan fixture.
  9. Clean the dust with a very soft toilet paper.
    • Clean the dust with a very soft toilet paper.
  10. This is what I´ve  found inside one fan !
    • This is what I´ve found inside one fan !
終わりに
11 の人々がこのガイドを完成させました。
LAOMUSIC ARTS
メンバー登録日: 2017年02月25日
565 ポイント
1ガイドが承認済み
4 件のコメント
I’d be careful about using a vacuum cleaner on the inside of the computer as it can cause static discharge and zap your components.
pov - 返信
Thanks a lot s
Sanzi Gao - 返信
Sanzi Gao - you are welcome!
LAOMUSIC ARTS - 返信
@laomusicarts do you know where I might be able to get an HD-74501 screwdriver. New or Used?
Kendall Lui - 返信
コメントを追加
統計データを表示:
過去 24時間: 6
過去 7 日: 22
過去 30 日: 74
今までの合計 7,563
