この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Removing a few screws will remove this part and allow access to your RAM.
必要な工具と部品
Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
9 の人々がこのガイドを完成させました。
