この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Two RAM slots allow up to 2 GB of PC2-5300 RAM.
必要な工具と部品
Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
113 の人々がこのガイドを完成させました。
2 件のコメント
My 1261 came w/2 of the 2gig sticks and If I understand things I'read here, I buy a 4 gig stick and replace one of the already installed 2 gig sticks and the machine will see and use 6. Is this about it?
Jim in Chicago
Yes Jim, that is it.
