はじめに
You can again use ExpressCard accessories by replacing a faulty ExpressCard cage.
必要な工具と部品
Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Disconnect the hard drive ribbon cable and the left I/O board ribbon cable from the logic board.
Disconnect the right speaker connector from the left I/O board.
6 の人々がこのガイドを完成させました。
