はじめに
Use this guide to replace the lower case in your MacBook Pro 16" late 2023 (M3 Pro/M3 Max).
Some photos in this guide are of the previous model MacBook Pro and may contain slight visual discrepancies, but they won't affect the procedure.
必要な工具と部品
Use a P5 Pentalobe driver to remove eight screws securing the lower case:
Four 9.2 mm screws
Four 5 mm screws
Press a suction handle into place near the front edge of the lower case, between the screw holes.
Pull up on the suction handle to create a small gap under the lower case.
Insert an opening pick into the gap you just created.
Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
Repeat the previous step on the other side, using an opening pick to to release the second clip.
Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
Remove the lower case.
Set it in place and align the sliding clips near the screen hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 16" Late 2023 Answers community for help.
ある他の人がこのガイドを完成しました。
コメント 1 件
Where can I buy MacBook Pro 16" Late 2023 Lower Case? Searched around the web for a while now and still no luck :( Any ideas?
