はじめに
Use this guide to replace a broken display assembly. The display assembly includes the LCD, front glass, display enclosure, iSight camera, and AirPort antennas.
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Pull the camera cable connector straight out of its socket on the logic board.
Remove the 8.6 mm Phillips screw securing the antenna/camera cable retainer to the upper case.
Remove the antenna/camera cable retainer from the upper case.
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
49 の人々がこのガイドを完成させました。
8 件のコメント
My macbook pro mid 2012 has a horizontal pixel line. It appeared after an actualization. Do you think it could be a matter of the display or software? Thank you
Actualization? What does that mean in this context?
Oh, accident. Most likely a hardware issue with the LCD itself.
This is not a difficult procedure. It takes about 10 minutes, half that if you know what you're doing, maybe twice that if you don't have a clue.
maccentric - 返信
so I did the dc port succesfully because it started, but now it starting up immediately to a white screen and has a loud fan noise, Also the magsafe light stays off. but i need the files and pgp keys on this mac, now, i have a workstation,iMac, if i were to use target disk mode, would they know that i did this at Apple?and if there is a chace of a kernal panic ?woud have to send my work station in. no time machine back i know ... Please dont lecture me. So far i did a nvram reset while it was on the white scren some how it just boots back to white screen. when i do s tandard smc reset it doesnt boot at all. when i do a nvram on the white screen it just resets itsef. cannot get nto recovery becasue its just a white screen. I also do various other ways of smc resets, but it llways boots to white scren, is this dsplay? do i have to replace the dispaly as per guide? what's happening,any ideas?
