はじめに
ワイヤレス接続に問題がありますか?このガイドを使って、機能しないAirPort/Bluetoothボードを交換します。
必要な工具と部品
スパッジャーの平面側を使って、AirPort/Bluetoothケーブルコネクタを基板から引き抜きます。
黒色のプラスチック製AirPort/Bluetoothハウジングの上部からAirPort/Bluetoothリボンケーブルを丁寧に剥がします。
デバイスを再組み立てする際は、これらの手順を逆の順番に従って作業を進めてください。
31 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
5 件のコメント
I didn't even have to replace my daughterboard -- I ordered a used one, but simply "reseating" (removing and attaching it again) the ribbon cable to the daughter board fixed my problem that the WiFi and Bluetooth card was invisible to the OS.
Thanks anyway for these great instructions! Without them I hadn't even thought about that the WiFi functionality was on a daughterboard... I thought other than in most "Windows laptops" that functionality was integrated into the main board.
Ralf Bergs - 返信
Excellent guide! The whole thing took me about 30 minutes and as soon as I turned on my mac again the WiFi worked perfectly.
I replaced both the card and the ribbon cable. Still get the message that there is no WiFi device installed. 15" MBP, mid-2010. The Bluetooth and Ethernet still work. But it is very inconvenient not having WiFi. Any thoughts on what else to try would be appreciated.
Raymond Steinbart
rsteinbart - 返信
Excellentguide as usual, but not sure the anntena cables should have be replaced in their housings before the Airport/ Bluetooth bracket was secured. Was there a reason I missed.
Peter Mayo - 返信
Is it possible to upgrade? Is there any “successor” known for Bluetooth 4.0 ?
Thanks
