メインコンテンツにスキップ
MacBook Pro 15" Unibody Late 2011 Display Replacement
必要な工具と部品
  1. MacBook Pro 15" Unibody Late 2011 Display Replacement, Lower Case: 手順 1、 1の画像 1
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. MacBook Pro 15" Unibody Late 2011 Display Replacement: 手順 2、 1の画像 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Late 2011 Display Replacement, Battery Connector: 手順 3、 2の画像 1 MacBook Pro 15" Unibody Late 2011 Display Replacement, Battery Connector: 手順 3、 2の画像 2
    • For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but is recommended as it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
  4. MacBook Pro 15" Unibody Late 2011 Display Replacement: 手順 4、 1の画像 1
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. MacBook Pro 15" Unibody Late 2011 Display Replacement, AirPort/Bluetooth Board Assembly: 手順 5、 1の画像 1
    • Pull the camera cable connector straight out of its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the optical drive opening.
  6. MacBook Pro 15" Unibody Late 2011 Display Replacement: 手順 6、 1の画像 1
    • Use the flat end of a spudger to carefully pry the AirPort/Bluetooth ribbon cable up off its socket on the logic board.
  7. MacBook Pro 15" Unibody Late 2011 Display Replacement: 手順 7、 2の画像 1 MacBook Pro 15" Unibody Late 2011 Display Replacement: 手順 7、 2の画像 2
    • Use the tip of a spudger to pry the four antenna connectors up from their sockets on the AirPort/Bluetooth board.
  8. MacBook Pro 15" Unibody Late 2011 Display Replacement: 手順 8、 3の画像 1 MacBook Pro 15" Unibody Late 2011 Display Replacement: 手順 8、 3の画像 2 MacBook Pro 15" Unibody Late 2011 Display Replacement: 手順 8、 3の画像 3
    • De-route all four antenna cables from their channels in the AirPort/Bluetooth housing.
    • De-route the camera cable from its channel in the AirPort/Bluetooth housing.
  9. MacBook Pro 15" Unibody Late 2011 Display Replacement: 手順 9、 1の画像 1
    • Remove the following two screws securing the AirPort/Bluetooth assembly to the upper case:
    • One 8.6 mm Phillips screw
    • One 3.9 mm Phillips screw
  10. MacBook Pro 15" Unibody Late 2011 Display Replacement: 手順 10、 1の画像 1
    • Remove the AirPort/Bluetooth assembly from the upper case, minding any cables that may get caught.
  11. MacBook Pro 15" Unibody Late 2011 Display Replacement, Display: 手順 11、 2の画像 1 MacBook Pro 15" Unibody Late 2011 Display Replacement, Display: 手順 11、 2の画像 2
    • Remove the 8.6 mm Phillips screw securing the antenna/camera cable retainer to the upper case.
    • Remove the antenna/camera cable retainer from the upper case.
    • During reassembly, place the nearby metal grounding tab on top of the hole that the Phillips screw goes into, and then install the screw.
  12. MacBook Pro 15" Unibody Late 2011 Display Replacement: 手順 12、 1の画像 1
    • Remove two of the three 6 mm T6 Torx screws securing the right side of the display to the upper case.
    • We purposely have you leave one screw attaching the display to the upper case to aid in future steps.
    • Before reinstalling the screw nearest to the corner of the case, make sure the nearby metal grounding tab doesn't get caught under the hinge.
  13. MacBook Pro 15" Unibody Late 2011 Display Replacement: 手順 13、 3の画像 1 MacBook Pro 15" Unibody Late 2011 Display Replacement: 手順 13、 3の画像 2 MacBook Pro 15" Unibody Late 2011 Display Replacement: 手順 13、 3の画像 3
    • Grab the plastic pull tab secured to the display data cable lock and rotate it up and over the connector, toward the DC-In side of the computer.
    • Pull the display data cable straight back (not up) out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  14. MacBook Pro 15" Unibody Late 2011 Display Replacement: 手順 14、 2の画像 1 MacBook Pro 15" Unibody Late 2011 Display Replacement: 手順 14、 2の画像 2
    • Remove the 8.6 mm Phillips screw securing the display data cable retainer to the upper case.
    • Remove the display data cable retainer from the upper case.
  15. MacBook Pro 15" Unibody Late 2011 Display Replacement: 手順 15、 1の画像 1
    • Remove two of the three 6 mm T6 Torx screws securing the left side of the display to the upper case.
    • The display assembly and MacBook body can be subtly misaligned on reassembly. With all six T6 Torx screws in place and the notebook closed, check for alignment. Loosen these six screws to correct the alignment if necessary, and then re-tighten them.
  16. MacBook Pro 15" Unibody Late 2011 Display Replacement: 手順 16、 1の画像 1
    • Open your MacBook Pro so the display is perpendicular to the upper case.
    • Place your opened MacBook Pro on a table as pictured.
    • While holding the display and upper case together with your left hand, remove the remaining T6 Torx screw from the upper display bracket.
  17. MacBook Pro 15" Unibody Late 2011 Display Replacement: 手順 17、 1の画像 1
    • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining T6 Torx screw securing the display to the upper case.
  18. MacBook Pro 15" Unibody Late 2011 Display Replacement: 手順 18、 3の画像 1 MacBook Pro 15" Unibody Late 2011 Display Replacement: 手順 18、 3の画像 2 MacBook Pro 15" Unibody Late 2011 Display Replacement: 手順 18、 3の画像 3
    • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
    • Rotate the display slightly away from the upper case.
    • Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
終わりに
37 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Miroslav Djuric
158,313 ポイント
144のガイドは作成済み
2 件のコメント
Hello there
Half a cup of water fell on my MacBook Pro and I tried to quickly dry it out of the water, and I turned on the laptop after more than four hours, but the screen did not work.  There are graphics on the screen, but the lighting does not work.  Today I changed the screen, but the problem still persists.  The lighting of the keys is on, but the lighting of the screen does not work. So please could you help me?
joan - 返信
Just Perfect, Thanks for your Help !!
xxb - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 21
過去 30 日: 72
今までの合計 40,476
