はじめに
Use this guide to replace a worn-out battery. If your battery is swollen, take appropriate precautions.
必要な工具と部品
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the attached plastic pull tab to remove the battery from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
134 の人々がこのガイドを完成させました。
5 件のコメント
It would be nice if you provided a Y1 tri wing bit with the replacement battery you sell.
geoffbowen - 返信
My battery had swelled, making the triblade screws extra tight. Other than that - silky smooth guide.
Great guide. Battery came out smoothly and new battery installed without issue. However, the battery I purchased here only lasted 3 months. I completed all the recommended steps to reset SMC and NVRAM but the battery now only lasts 10 minutes off the charger. Thankfully I kept my original battery and placed it back in the MBP and I’m now attempting to return the battery despite being out of the 30 day return period.
Not sure why this is rated moderately difficult. It’s a pretty easy job.
santamaria - 返信
I successfully replaced the battery, calibrated it, and worked fine for 4 charge cycles…..after this the battery just went dead!
The reported “battery condition” in the system Report says: “Replace now”…(!!!??).
Battery indicator in the desktop screen reports 100% charged, but system report states battery fully charged but with amperage (mA): 0
I tried to reset the SMC as per Apple’s website instructions for this MacBook Pro (15” late 2011). It did not resolve the problem either.
Was this a defective battery?
