メインコンテンツにスキップ
MacBook Pro 15インチ Unibody Late 2008とEarly 2009右側ファンの交換
必要な工具と部品
  1. MacBook Pro 15インチ Unibody Late 2008とEarly 2009右側ファンの交換, アクセスドア: 手順 1、 2の画像 1 MacBook Pro 15インチ Unibody Late 2008とEarly 2009右側ファンの交換, アクセスドア: 手順 1、 2の画像 2
    • ケースを閉じた状態で、平らな作業台の上にUnibodyの上部を下側に向けて配置します。
    • アクセスドアの取り外しラッチの溝のある側を押して、飛び出した側の先端を掴んでください。取り出しラッチを垂直になるまで持ち上げます。
    The A1286 has no Access Door.!!
    I actually can see no sign of the battery!...
    aguib - 返信
    aguibからの引用:
    I assume you have the newer model, with the built-in battery. It's still removable with tools, but these are the wrong instructions for that model.
    lgc90 - 返信
    when will there be a guide for the other unibody macbook pro. that does not have an access door?
    irishking - 返信
    Is there a manual to show, how disasembly the display, i mean, after step 5, to check the display between lcd and aluminiun back case?
    Max
    Max - 返信
    On other guides you state the height of the HD that can be supported, e.g. MacBook Pro 15" Core 2 Duo Model A1211 Hard Drive Replacement , I have read ( but have not confirmed ) that the uni-body MacBook Pro can be fitted with the 750GB and 1TB 12mm drive from Western Digital.
    Can you confirm this?
    Many thanks in advance.
    ahothabeth - 返信
    SHerwood Ballからの引用:
    My display and aluminum casing has separated.
    I don't know if it just snaps back together or does it need to be glued.
    I dropped mine on the carpeted stairs and the display still works.
    I'm hoping I can just snap it back together and that no plastic pieces or teeth of the snapping
    portion have been broken........
    SHerwood Ball - 返信
    When you say "left fan" is this "left when looking at the logic board after turning the computer over and looking it up opening it up" or "left when sitting at the computer keyboard and typing on it"?
    thvv - 返信
    We always use left and right in reference to the computer when you're using it.
    Andrew Optimus Goldheart -
    Directions were great and the worn dc in board was replaced. The hardest part of the procedure is disconnecting the data display cable. A better description of step 21 is to slide the connector parallel to the circuit board towards the outside corner. Reconnecting correctly took several tries.
    I used the tip of the spudger to nudge the corners a little at a time to seat the connector.
    The ribbon connector for the keyboard has to be inserted all the way before seating the retaining cap. It took me three tries . First try power button did not work second try numbers keys did not work.
    Thanks for the directions ...could not have done it with out them!!!
    landryd - 返信
    Hola. Poseo un MacBook Pro Late 2008 y debo cambiarle las cornetas. Me sirve unas cornetas de un MBP Late 2011?
    jegonzalez80 - 返信
    Please read the instructions about removing the bluetooth cable - you CAN work around it, and NOT take off the plug.
    kenneth krabat - 返信
  2. MacBook Pro 15インチ Unibody Late 2008とEarly 2009右側ファンの交換: 手順 2、 1の画像 1
    • アクセスドアがUnibodyから十分の高さまで持ち上がるはずです。
  3. MacBook Pro 15インチ Unibody Late 2008とEarly 2009右側ファンの交換, バッテリー: 手順 3、 1の画像 1
    • 次の手順に進む前に、アクセスドアの取り外しラッチが垂直になっているか確認してください。
    • 半透明のプラスチックタブを掴んで、バッテリーをUnibodyから引き上げます。
    • ラッチが押されると、バッテリーが所定の位置にロックされます。
    Do I need to wait for the battery to charge completely before using the computer (while plugged in)?
    Kaila Potts - 返信
    No. You do not need to charge it completely before removing it.
    Titus (#1579) - 返信
  4. MacBook Pro 15インチ Unibody Late 2008とEarly 2009右側ファンの交換, 下部ケース: 手順 4、 1の画像 1
    • 下部ケースにカシス(筐体)を固定している次の8本のネジを外します。
    • 5.4 mmプラスネジー1本
    • 14 mmプラスネジー3本
    • 3.5 mmプラスネジー4本
    Hi, My name is Jess I need help asap I accidentally dropped my macbook Pro and i cant find the silver screw for the top left back side, Does any one know if I can replace it with an eye glass screw?? If you can help at all Please e-mail me at Chambliss_jess@yahoo.com thx please help me my bf is going off... ;(
    Jess - 返信
    The fixit PH00 is the wrong screw driver for this entire job. It did not fit in the screws, it was too pointy and caused screws to be rounded off.
    mattrittgers - 返信
  5. MacBook Pro 15インチ Unibody Late 2008とEarly 2009右側ファンの交換: 手順 5、 1の画像 1
    • 両手を使って、上部ケースから下部ケースを持ち上げて取り出します。
    About midway along each edge is a snap. To release each snap, gently slide the flat edge of a Spudger under the lower case, then lift the lower case away.
    jonathansturges - 返信
  6. MacBook Pro 15インチ Unibody Late 2008とEarly 2009右側ファンの交換, 右側ファン: 手順 6、 2の画像 1 MacBook Pro 15インチ Unibody Late 2008とEarly 2009右側ファンの交換, 右側ファン: 手順 6、 2の画像 2
    • スパッジャーを使って、ロジックボード上のソケットからファンコネクタをまっすぐ引き上げて、外します。
    • コネクタ自体をこじ開けてください。ソケットには接触しないでください。デバイスにダメージを与えてしまいます。
    • ファンケーブルワイヤーの下から、スパッジャーを軸方向にツイストするとコネクタが外れやすくなります。
    Did it the way described. Maybe because of the age of the Mac/circuit board but the sockets came out with the connector. Only solution now for this fan to work would be to hard solder. Not a happy outcome.
    Nicole Bokat - 返信
  7. MacBook Pro 15インチ Unibody Late 2008とEarly 2009右側ファンの交換: 手順 7、 1の画像 1
    • ロジックボードと上部ケースに右側ファンに固定している次の3本のネジを外します。
    • 3.2 mm プラスネジー2本
    • 3.5 mm プラスネジー1本
    I ruined the head of the heads of the 3.2 mm and the 3.5 Phillips screws. What kind of screws are this (M1, M1.2, ...?)? I need a replacement.
    PS I used the appropriate screw driver (Wiha PH00).
    Michael Domhardt - 返信
    Hi! how did you fix it? I ruined the last two red 3,2 mm screws as well, so the old fan is still in there....
    laurabaas94 -
    I can't seem to get the two (2) 3.2 screws out, they are in way too tight. I'm afraid of rounding out the slots and putting too much pressure on the board. No issues with replacing the other fan..any hints/tricks to getting these screws out? thanks
    Joseph Vossen - 返信
    Same problem here, killed the head of the top left 3.2 mm screw … any ideas how to get it out now?
    Max Bobzien - 返信
    I have been reading this so many times …
    “”killed the head screws “”
    May I suggest , open your laptop at L shape
    Upside down keyboard on your desk but your screen vertical out the way !
    And doing a little more pressure with out rush very gently breaking loctite paint ….
    Good luck guys 🤙🏻
    analfabetagoloso - 返信
  8. MacBook Pro 15インチ Unibody Late 2008とEarly 2009右側ファンの交換: 手順 8、 1の画像 1
    • 上部ケースからファンを持ち上げます。
終わりに
デバイスを再組み立てする際は、これらの手順を逆の順番に従って作業を進めてください。
71 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
作成者
5人の作成者と共同で作成されました。
Walter Galan
694,561 ポイント
1,203のガイドは作成済み
コメント 1 件
A great walkthrough.
Once completed, I did a reset of the PRAM, and it all worked beautifully.
Thanks again.
Shai Yammanee - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 10
今までの合計 41,170
