メインコンテンツにスキップ
MacBook Pro 15" Unibody Late 2008 and Early 2009 Left Fan Replacement
必要な工具と部品
  1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Left Fan Replacement, Access Door: 手順 1、 2の画像 1 MacBook Pro 15" Unibody Late 2008 and Early 2009 Left Fan Replacement, Access Door: 手順 1、 2の画像 2
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
  2. MacBook Pro 15" Unibody Late 2008 and Early 2009 Left Fan Replacement: 手順 2、 1の画像 1
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. MacBook Pro 15" Unibody Late 2008 and Early 2009 Left Fan Replacement, Battery: 手順 3、 1の画像 1
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the translucent plastic tab and pull the battery up and out of the Unibody.
    • If the latch is depressed it will lock the battery in place.
  4. MacBook Pro 15" Unibody Late 2008 and Early 2009 Left Fan Replacement, Lower Case: 手順 4、 1の画像 1
    • Remove the following eight screws securing the lower case to the chassis:
    • One 5.4 mm Phillips screw.
    • Three 14 mm Phillips screws.
    • Four 3.5 mm Phillips screws.
  5. MacBook Pro 15" Unibody Late 2008 and Early 2009 Left Fan Replacement: 手順 5、 1の画像 1
    • Using both hands, lift and remove the lower case off the upper case.
  6. MacBook Pro 15" Unibody Late 2008 and Early 2009 Left Fan Replacement, Left Fan: 手順 6、 2の画像 1 MacBook Pro 15" Unibody Late 2008 and Early 2009 Left Fan Replacement, Left Fan: 手順 6、 2の画像 2
    • Use a spudger to pry the fan connector straight up off the logic board.
    • Be sure to only pry up on the connector itself not on the socket or you may damage the machine.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
  7. MacBook Pro 15" Unibody Late 2008 and Early 2009 Left Fan Replacement: 手順 7、 1の画像 1
    • Remove three 3.5 mm Phillips screws securing the left fan to the upper case and logic board.
  8. MacBook Pro 15" Unibody Late 2008 and Early 2009 Left Fan Replacement: 手順 8、 1の画像 1
    • Lift the fan out of the upper case.
終わりに
94 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Walter Galan
694,573 ポイント
1,203のガイドは作成済み
コメント 1 件
Very easy to do following the instructions, Thank you. A word of caution though, The fans screws are really tight so be careful and use a good fitting screw driver. The screw heads are easily damaged.
Poppy - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 14
今までの合計 55,459
