メインコンテンツにスキップ
MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換
必要な工具と部品
  1. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換, アクセスドア: 手順 1、 2の画像 1 MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換, アクセスドア: 手順 1、 2の画像 2
    • ケースを閉じた状態で、平らな作業台の上にUnibodyの上部を下側に向けて配置します。
    • アクセスドアの取り外しラッチの溝のある側を押して、飛び出した側の先端を掴んでください。取り出しラッチを垂直になるまで持ち上げます。
    The A1286 has no Access Door.!!
    I actually can see no sign of the battery!...
    aguib - 返信
    aguibからの引用:
    I assume you have the newer model, with the built-in battery. It's still removable with tools, but these are the wrong instructions for that model.
    lgc90 - 返信
    when will there be a guide for the other unibody macbook pro. that does not have an access door?
    irishking - 返信
    Is there a manual to show, how disasembly the display, i mean, after step 5, to check the display between lcd and aluminiun back case?
    Max
    Max - 返信
    On other guides you state the height of the HD that can be supported, e.g. MacBook Pro 15" Core 2 Duo Model A1211 Hard Drive Replacement , I have read ( but have not confirmed ) that the uni-body MacBook Pro can be fitted with the 750GB and 1TB 12mm drive from Western Digital.
    Can you confirm this?
    Many thanks in advance.
    ahothabeth - 返信
    SHerwood Ballからの引用:
    My display and aluminum casing has separated.
    I don't know if it just snaps back together or does it need to be glued.
    I dropped mine on the carpeted stairs and the display still works.
    I'm hoping I can just snap it back together and that no plastic pieces or teeth of the snapping
    portion have been broken........
    SHerwood Ball - 返信
    When you say "left fan" is this "left when looking at the logic board after turning the computer over and looking it up opening it up" or "left when sitting at the computer keyboard and typing on it"?
    thvv - 返信
    We always use left and right in reference to the computer when you're using it.
    Andrew Optimus Goldheart -
    Directions were great and the worn dc in board was replaced. The hardest part of the procedure is disconnecting the data display cable. A better description of step 21 is to slide the connector parallel to the circuit board towards the outside corner. Reconnecting correctly took several tries.
    I used the tip of the spudger to nudge the corners a little at a time to seat the connector.
    The ribbon connector for the keyboard has to be inserted all the way before seating the retaining cap. It took me three tries . First try power button did not work second try numbers keys did not work.
    Thanks for the directions ...could not have done it with out them!!!
    landryd - 返信
    Hola. Poseo un MacBook Pro Late 2008 y debo cambiarle las cornetas. Me sirve unas cornetas de un MBP Late 2011?
    jegonzalez80 - 返信
    Please read the instructions about removing the bluetooth cable - you CAN work around it, and NOT take off the plug.
    kenneth krabat - 返信
  2. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 2、 1の画像 1
    • アクセスドアがUnibodyから十分の高さまで持ち上がるはずです。
  3. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換, バッテリー: 手順 3、 1の画像 1
    • 次の手順に進む前に、アクセスドアの取り外しラッチが垂直になっているか確認してください。
    • 半透明のプラスチックタブを掴んで、バッテリーをUnibodyから引き上げます。
    • ラッチが押されると、バッテリーが所定の位置にロックされます。
    Do I need to wait for the battery to charge completely before using the computer (while plugged in)?
    Kaila Potts - 返信
    No. You do not need to charge it completely before removing it.
    Titus (#1579) - 返信
  4. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換, 下部ケース: 手順 4、 1の画像 1
    • 下部ケースにカシス(筐体)を固定している次の8本のネジを外します。
    • 5.4 mmプラスネジー1本
    • 14 mmプラスネジー3本
    • 3.5 mmプラスネジー4本
    Hi, My name is Jess I need help asap I accidentally dropped my macbook Pro and i cant find the silver screw for the top left back side, Does any one know if I can replace it with an eye glass screw?? If you can help at all Please e-mail me at Chambliss_jess@yahoo.com thx please help me my bf is going off... ;(
    Jess - 返信
    The fixit PH00 is the wrong screw driver for this entire job. It did not fit in the screws, it was too pointy and caused screws to be rounded off.
    mattrittgers - 返信
  5. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 5、 1の画像 1
    • 両手を使って、上部ケースから下部ケースを持ち上げて取り出します。
    About midway along each edge is a snap. To release each snap, gently slide the flat edge of a Spudger under the lower case, then lift the lower case away.
    jonathansturges - 返信
  6. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換, ミッドウォール: 手順 6、 1の画像 1
    • 上部ケースにミッドウォールを固定している次のネジを5本外します。
    • 10.5 mmプラスネジ−3本
    • 3.7 mmプラスネジー2本
  7. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 7、 1の画像 1
    • 上部ケースからミッドウォールを持ち上げます。
  8. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換, 基板: 手順 8、 1の画像 1
    • 右側・左側ファンと基板を固定している次の6本のネジを外します。
    • 3.5 mmプラスネジー4本
    • 3.2 mmプラスネジー2本
    Pry under the side where the wires connect.
    colleenthompson - 返信
    I think this the screw dimensions may be reversed. My late 2008 Unibody had four 3.2mm and two 3.5mm.
    Christian Lallo - 返信
  9. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 9、 3の画像 1 MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 9、 3の画像 2 MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 9、 3の画像 3
    • スパッジャーの先端を使って、右側ファンのコネクタを基板上のソケットからまっすぐ引き上げます。
    • ソケットではなく、コネクタ自体を引き上げてください。ソケットに接触すると、デバイスにダメージを与えてしまいます。
    • コネクタを解放するには、ファンケーブルワイヤの下からスパッジャーを捻りながら差し込むと作業がしやすくなります。
    • ケースから右側ファンを取り出します。
    Be really gentle and patient with this connector, I popped the socket right off of the logic board (thankfully the already broken one that I was replacing). It actually shouldn't take much force, and just gently work on it until it comes out.
    Mark Middleton - 返信
  10. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 10、 3の画像 1 MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 10、 3の画像 2 MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 10、 3の画像 3
    • スパッジャーの先端を使って、基板上のソケットから左側ファンのコネクタをまっすぐ引き抜きます。
    • コネクタ自体を引き抜いてください。ソケットには接触しないでください。デバイスにダメージを与えてしまうことがあります。
    • コネクタを解放するには、ファンケーブルワイヤの下からスパッジャーを差し込み、捻りながら外すと便利です。
    • ケースから左側ファンを取り出します。
    I unfortunately broke the fan receptacle connector (2 pin) on the board. How do I order a new connector and how do I put it on?
    Kevin Hamby - 返信
  11. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 11、 1の画像 1
    • カメラケーブルのコネクタから接着剤を剥がします。
    • ケーブルのオス型の先端をソケットから引っ張り、カメラケーブルの接続を外します。上向きに引っ張らず、基板と水平に引っ張ります。
    There's a little shiny piece of plastic holding this item in place to keep it from sliding out of it's slot. It's glued on and if you don't take it off first, you'll likely bend the connector so that it won't work anymore. Ruined a motherboard because this step was missing.
    maccentric - 返信
    What this guy said - REMOVE the shiny plastic block first. Also the "straight away" means sliding outwards TOWARDS THE OPTICAL BAY - *NOT* upwards.
    Damien - 返信
    I broke the connector for the subwoofer. Do I have to replace the logic board?
    jbp0471 - 返信
    It is not necessary to disconnect the camera cable to remove/replace the left speaker. You can leave the cable connected to save you from damaging it.
    Daniel Fišer - 返信
  12. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 12、 1の画像 1
    • スパッジャーを使って、ゆっくりと光学ドライブコネクタを基板上のソケットからまっすぐ引き抜きます。
  13. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 13、 1の画像 1
    • 必要に応じて、サブウーファーのコネクタを覆っているフォーム製のバンパーカバーを剥がします。
    • スパッジャーの平面側先端を使って、基板上のソケットからサブウーファーのコネクタをまっすぐ引き抜きます。
    • 作業にはご注意ください。このコネクタはデリケートで、ソケットは基板から簡単に壊れてしまいます。
    I Broke the subwoofer socket on the logic board. Can I use without subwoofer, or do I now have to replace the logic board?
    jbp0471 - 返信
    Sorry to hear this. Yes, you can use the machine without the subwoofer. To be safe, cover the subwoofer plug with some electrical tape so that it can't cause a short circuit somewhere.
    Marty Swartz -
  14. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 14、 1の画像 1
    • スパッジャーの平面側先端を使って、シルバーのハードドライブケーブルコネクタを基板上のソケットからまっすぐ引き抜きます。
  15. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 15、 1の画像 1
    • スパッジャーを使って、基板上のソケットからトラックパッドコネクタをまっすぐ引き抜きます。
  16. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 16、 2の画像 1 MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 16、 2の画像 2
    • スパッジャーの先端を使って、赤外線/スリープLEDリボンケーブルの固定フラップを裏返します。
    • 赤外線/スリープLEDリボンケーブルをソケットからまっすぐ引き抜きます。
    Hi, thanks for this tutorial: it solved my problem.
    But unfortunately I have broken the IR/sleep LED ribbon cable socket on motherboard (cable is ok, socket crumbled): computer works fine but now it doesn't go on standby anymore. Is there a way to fix the cable on motherboard (for example with Kapton tape) or is there a software to manage computer standby?
    Thanks in advance for your help.
    Mary
    mary - 返信
    Hi, thanks for this tutorial, it is really helpful. Unfortunately I cannot push the ribbon cable into the socket. The space is really limited, the cable is hard, and the socket seems to be too narrow. Is there any tool to push this kind of cable in a short space? Very fine plastic tweezers could work? Even without this cable the Mac can work, so I leave it before I break it.
    Hideyuki
    Hideyuki Tatsuno - 返信
  17. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 17、 1の画像 1
    • スパッジャーを使って、バッテリーインディケーターのライトコネクタを基板上のソケットからまっすぐ引き抜きます。
    • ケーブルワイヤの下にスパッジャーを差し込みます。基板上のソケットを引き抜かない様、ご注意ください。
  18. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 18、 2の画像 1 MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 18、 2の画像 2
    • スパッジャーの先端を使って、キーボードのリボンケーブルの固定フラップを裏返します。
    • キーボードのリボンケーブルをソケットからまっすぐ引き抜きます。
    • 再組み立ての際には、キーボードのリボンケーブルがZIFソケットにしっかりと装着されているか確認してください。
    I ran into trouble when re-installing the keyboard cable. I got everything put back together, plugged it in, and pressed Power... and nothing happened. I took everything apart again, reseated the heat sink and everything, put it back together... and the Power button didn't respond.
    The MagSafe light came on, and the battery charge lights came on. But it wouldn't power up.
    Finally I figured out that the keyboard cable is really tricky to get in correctly. If you can slide it out with the retaining clip locked (applying very little pressure), then the cable isn't actually in correctly. I had to really fiddle with it, and maybe slide it in one side first, to see that it actually needed to slide in another 1/8th inch or so beyond what felt like "in" the first few times I did it.
    Once I'd secured that cable, my MacBook turned on again without a problem. So far, after just replacing the Thermal Paste (I didn't actually install a new heat sink), the computer is running 20°F cooler than it has in years. Thanks!
    simolinic - 返信
    I think I broke the keyboard ribbon cable, now I have to replace the keyboard.....
    Francesco Zhu -
    I agree. The instructions should place emphasis on seeing how deep this ribbon is. Most ribbons are pretty easy to slot back in. This one is not (maybe because of the colour). The IR/sleep is a b... too!
    Jerome - 返信
    Hi Jerome. Thank you for your feedback. I agree with you and simolinic. There should be a reminder bullet that warns people about the depth of the ribbon cable. Thanks for adding that. Much appreciated.
    Walter Galan -
    Thank you simonlinic, for pointing this out. I was so disapppointed when the MacBook Pro wouldn't start up. I reopened the MacBook and was able to insert the keyboard ribbon cable quite a bit more by pushing agains the top of the cable while inserting it. I tired starting up after that and it still wouldn't start. I took a 15 minute break and then it started up perfectly! I'm grateful to you all!
    Sy Bram - 返信
    Here is the best way to reinsert this cable: MacBook unibody keyboard ribbon cable won't go in Putting a piece of tape on the connector (creating a pull-tab) and pulling it in works great.
    Cooper - 返信
  19. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 19、 2の画像 1 MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 19、 2の画像 2
    • スパッジャーの先端を使って、エクスプレスカードケージのリボンケーブル固定フラップを持ち上げます。
    • エクスプレスカードケージリボンケーブルをソケットからまっすぐ引き抜きます。
  20. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 20、 1の画像 1
    • スパッジャーの平面側先端を使って、マイクケーブルコネクタを基板上のソケットからまっすぐ引き抜きます。
    • ケーブルワイヤの下から差し込みます。基板上のソケットには接触しないようご注意ください。
    I don't believe this step is actually necessary, the cable is attached on the other side of the logic board and comes along with it, so it just isn't really necessary to disconnect (although it's not hard either).
    Trevor Kemp - 返信
  21. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 21、 2の画像 1 MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 21、 2の画像 2
    • ディスプレイのデータケーブルのロックに付けられたプラスチックのプルタブを掴み、コンピューターのDC-in側に向けて回転させます。
    • ディスプレイデータケーブルコネクタをソケットからまっすぐ引き抜きます。
    • ディスプレイデータケーブルの接続を外す際は、ケーブルのロックに付けられた黒色のタブを引っ張らないでください。コネクターをソケットからゆっくりと伸ばしながら、ケーブルを振ってみることをおすすめします。
    • ディスプレイのデータケーブルが正しくソケットに装着されているか確認してください。きちんと装着できていなければ、ディスプレイ上の表示が半分もしくは全く表示されないという状態になります。
  22. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 22、 2の画像 1 MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 22、 2の画像 2
    • キーボードのバックライトリボンケーブル(左側ファンのスペース付近)を確認します。
    • スパッジャーの先端を使って、キーボードのバックライトリボンケーブルの固定フラップを裏返します。
    • キーボードのバックライトリボンケーブルをソケットからまっすぐ引き抜きます。
  23. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 23、 1の画像 1
    • 上部ケースに基板を固定している3.2 mmプラスネジを7本外します。
    • まだ基板を外さないでください!基板の下側にコネクタが接続されたままです。まずこのコネクタの接続を外さなければなりません。
    On reassembly, check carefully that none of the fiddly little cables are trapped under the logic board. I had to back up and liberate the subwoofer connector. It takes some careful jiggling to get the sockets seated in the port holes.
    The two screws closest to the optical drive have smaller heads. (May not be critical.)
    Marty Swartz - 返信
  24. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 24、 1の画像 1
    • 上部ケースにDC-inボードを固定している7 mmプラスネジを2本外します。
    • ご注意:この手順は必ずしも必要ではありませんが、DC-inボードに接続されたケーブルの接続を外す際には作業が簡単になります。
  25. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 25、 2の画像 1 MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 25、 2の画像 2
    • 上部ケースに下部ケースのクリップを固定している3.5 mプラスネジを2本外します。
    • 上部ケースから下部ケースのクリップを持ち上げて取り出します。
    • あるモデルのMacBook Pro Unibodyにはこのクリップがついていない場合があります。その場合は、この手順は不要です。
    My clip is oriented 180 degrees (flipped) from this picture.
    The bottom case clip is screwed to a black plastic bracket that's glued onto the upper case. My replacement upper case did not come with this bracket. I had to carefully pry it off the old upper case, taking care not to break it, and glue it to the new upper case before replacing the logic board.
    I have a 2.66ghz 15inch Unibody Macbook Pro (A1286) and this step was not necessary.
    Andrew Magpoc - 返信
    Andrew Mostajoからの引用:
    I have a 2.66ghz 15inch Unibody Macbook Pro (A1286) and this step (24) was not necessary.
    Andrew Magpoc - 返信
    Apropos to the last tip in this step, the replacement unibody I purchased omitted the receiving end of this clip, but it was in my original. As it only captures (but does not secure) a small metal tab on the bottom cover, I skipped transferring it.
    Brett Deriso - 返信
    Agree with @colleenthompson - mine was also rotated 180 degrees from what is shown, which also matches the other side of the computer.
    Trevor Kemp - 返信
  26. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 26、 2の画像 1 MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 26、 2の画像 2
    • 左側から基板アセンブリを持ち上げて、上部ケースから取り出します。側にある端子が絡まないようご注意ください。
    • まだ基板を完全に取り出さないでください!
    • 次の手順に進む前に(バッテリコネクタ以外)、基板から上部ケースに接続された全てのコネクタを外しているか確認してください。
    • 再組み立ての際には、全てのコネクタとケーブルが基板の下に残されていないか確認してください。あるリボンケーブルは大変薄く、壊れやすいものがあります。
  27. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 27、 2の画像 1 MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 27、 2の画像 2
    • バッテリーコネクタを十分つかめるほどの高さまで基板を持ち上げ、基板上のソケットからまっすぐ引き抜きます。
    • 基板アセンブリを上部ケースから持ち上げます。
    I didn't have to do this step, I just leaned the logic board up and changed the DC board.
    dmeyer302 - 返信
    Its better to carefuly “flip” the board towards battery compartment and then take the connector out. The way, how it is written here, its badly accessible with fingers and with tweezers and the connector has plastic point which clicks into hole in the middle of connector. So its better to carefully flip the board upside out and then take it carefully out.
    Petr Sourek - 返信
  28. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換, ヒートシンク: 手順 28、 1の画像 1
    • ロジックボードにヒートシンクを固定している8.4 mmプラスネジを8本外します。
    • これらの各ネジの下にバネが付いています。
    When replacing the screws, how many times should each one be turned? All the way, or 3/4, or 1/2?
    I should have paid attention before removing them. Thanks for the help!
    wahjohn2002 - 返信
  29. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 29、 1の画像 1
    • スパッジャーの先端を使って、ロジックボードからサーマルセンサのコネクタを引き抜きます。
    • このコネクタは特にデリケートなため、取り外しの際はご注意ください。
    I broke this connector!!! Help! What can I do? Do I have to buy the whole heat sink?
    The problem is that the cable broke, and the connector remained inside the socket... and now I can't pull it off.
    Francesco Zhu - 返信
    UPDATE: Pulled the connector out. Any change I can reconnect it to the cables?
    Francesco Zhu -
  30. MacBook Pro 15" Unibody Late 2008/Early 2009 ヒートシンクの交換: 手順 30、 1の画像 1
    • ロジックボードからヒートシンクを丁寧に持ち上げます。
    • ヒートシンクをラップトップ本体に再取り付けする際は、サーマルコンパウンドを簡単に交換するための放熱グリスの塗布ガイドを参照してください。
終わりに
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
28 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
作成者
7人の作成者と共同で作成されました。
Walter Galan
694,674 ポイント
1,203のガイドは作成済み
4 件のコメント
Wonder why there are springs on the heat sink screws? Do not over tighten them, the springs are there to help you apply the correct amount of pressure on to the CPU and GPU. If you tighten them all the way, it may not be the correct pressure! Leave maybe 1 mm of space, just before the screw stops turning. iFixit forgot to mention this important part, and also in the heat paste guide!!
m3kw - 返信
My Macbook was over heating. i did these steps to put thermal paste but now my Macbook pro is not even opening.. please help..!!
Deepanshu Chaurasia - 返信
My old Macbook was getting pretty hot (90-110 C on the main processor temperature sensor) doing normal tasks so I decided it was probably the thermal paste going bad. Successfully completed this using this guide, typing this on that computer now, thanks! It took me about 3 hours all in, including setup and cleanup afterwards. I did not replace the heat pipe assembly itself, just redid the thermal paste. I am actually curious what the symptoms are that would lead to completely replacing the heat pipe assembly itself. Running much cooler now (59 C).
Trevor Kemp - 返信
I went through this last night to the T, made sure to be careful and put all cables back properly. Now when I start the laptop I get the startup noise, the screen will flicker really quick but then go back to black and stays black indefinitely. The keyboard lights come on and the laptop is running fine just no display. I’ve tried all the resetting pram and all of that to no avail. I have reseated the lcd cable multiple times and still have a black screen. At a loss.
Patrick Scroggins - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 37
今までの合計 37,441
